Starting a new thread on this issue as it was buried in a thread on another problem.
'71 Princeton Reverb
Synopsis:
What would do this in the reverb circuit? When a note is played the first time after the amp is turned on, the amp goes nuts with loud garbly hiss/crackle unaffected by volume control turned off. It stops entirely when you rotate the Reverb potentiometer up and down.
From the other day: "Suddenly today it started making a crackly garbly noise and fairly loud. (started with the first note of playing after the amp warmed up)
-Volume control didn't change that sound at all.... even off.
-I dimed the reverb, it got louder... then the noise quit entirely when I rolled back to 7-8.
- Played quite a bit more and loudly and no issues at all. "
It did this again last night at rehearsal, I rotated the Reverb knob and it quit..... was fine then for 3 hours after.
So I suspect something is going on in the Reverb circuit. Both reverb send and recovery tubes were changed yesterday.. For the T7 I put a NOS Sylvania Mil Spec in. For the recovery AX7 I put in a known proper working tube. So I doubt it's anything to do with those tubes, the amp did the same thing before and after.
The RCA cables ends were cleaned while I had the chassis out.
Just looking for hints of most likely candidates. I'll have to get the chassis out again to measure voltages on the reverb send and recovery tubes. What in the Reverb circuit would be effected, eliminating noise/problem by rotating/cycling the pot?
Synopsis:
