Garage heater suggestions?
Mechanic
Over the hill and far awa
I’m currently using a Mr Heat dual burner on propane. The garage is insulated and the door is insulated as well I crack the side door and garage doors about an inch. I can get it to about 65-70’F. I’m mostly doing engine work or milling and turning metals. Befor doing engine assembly work in my environment I need to do a floor scrub and walls vacuumed to keep the Craptonite out of a new engine. The heater makes it nice so the tools don’t stick to your fingers.
Mechanic
lariat 99
So how much electricity do these mini splits consume. I was thinking of putting one in the garage for the same reasons.
Jim_in_PA
SE PA - Doylestown PA
So much electricity do these mini splits consume. I was thinking of putting one in the garage for the same reasons.
Minisplits are super efficient. The one in the shop at my old property that I installed in 2018 barely blipped the power bill and it was running either on AC or heat for most of the year. With the previous resistance heating I was using and a window AC unit, power consumption was eye-opening...
wingcommander
Perth, Australia
I'm having the reverse problem.
We've just had 5 consecutive days with maximums > 40 degC (that's > 104 degF).
It's Bikram woodwork in my shed at the moment. ;)
Wooly Mammoth
United States
Thanks @Freeman Keller I am in a similar situation where I have a little buddy / Mr heater that I can run off the small green cans or a larger bbq tank.
Having just spent a few hours out there this am - I got the garage from 35f up to about 45f.
Each winter I think more often about upgrading.
Even the big buddy won't heat up a garage and if its insulated its not very safe.
Go electric if your panel has the power or LNG, whichever is easier to plumb/wire.
My brother has an electric in his insulated 4 car garage and it works well.
