Gah...24 frets with dot on 23rd fret
  • Thread starter ppg677
ppg677
WI
Welp first time making a 24 fret neck and I drilled a fret marker dot on fret 23, rather than double dots on 24. Dern.
What would you guys do?
1) leave it
2) cut off fret 23/24 and convert to 22 fret neck (I'd still have to patch a hole)
3) drill it out, patch it, and redrill double markers on fret 24?
4) just add double markers to fret 24
5) replace fretboard since I haven't fretted yet.
6) ??
jfgesquire
Lake View
Match the grain and plug it. Don't use a dowel as it will be end grain, you need to get a plug cutting bit.
I'm sure you have already investigated that.... similar to plugging and redrilling tuning peg holes...I remember seeing a Dan Erlewine video somewhere selling the StewMac bits.
Sent from my LG-H932 using Tapatalk
Macrogats
Auckland, New Zealand
I’m with DougM. Leave it as it is. Would be a very unique look, and as he said - you’ll easily know where fret 24 is.
Stunning looking fb btw. What’s the project? More info would be nice. You may as well turn this into a build thread now. :D
Canada
Change 23 to some kind of inlaid symbol or word with a middle letter that's "o", and then drill a two hole inlay in 24.
Right now it looks weird, like it has too many belly buttons.
matmosphere
earth
I say leave it. I don’t think it would take much to adjust to. It’s an optical illusion for guitar players.
Plus how often do you find yourself looking at those dots when you’re playing.
LowCaster
Paris, France
I don't like the look of the double dot on that las fret, feels weird to me and makes me think that you want to attract attention ont the fact that you have more frets that necessary. It's not really usefull either.
I'd just plug the 23th with something dark and decorative, your logo, whatever, make it look like it was intentional.
guitarbuilder
Ontario County
I'd drill and chisel out a slot between the fret slots. Then I'd replace the wood with a rectangle/square of scrap with similar grain and direction. The space between the frets and a good joint should be enough to really hide it. Then I'd get a dot in the right spot. My thought is that by trying to make something out of it only accentuates that you screwed it up in the first place.
