GA-FC and Blues Cube Artist
Discussion in 'Modeling Amps, Plugins and Apps' started by McGlamRock, Sep 18, 2021.
  1. McGlamRock
    McGlamRock Poster Extraordinaire
    San Francisco, CA
    I have a Blues Cube Artist arriving on Monday, and I also bought a used Boss GA-FC to activate tremolo, change channels, etc..
    Anyway the GA-FC arrived today, but I don't think this is going to work with the new amp. There is a 'delay' button (a feature the new amp does not have)
    Anyway, I was wondering what the odds are that this GA-FC will be compatible with a new Blues Cube Artist and be able to turn the tremolo on/off etc...? IMG_0159.jpeg
  2. hotraman
    hotraman Tele-Afflicted
    Camas, WA
    I own a GA-FC and have used with the my Katana head and Cube 40.
    I had to change the stickers because they didn't align with the amp.
    Did Blues Cube Artist come with the "preset" stickers for the GA-FC?
    McGlamRock likes this.
  3. McGlamRock
    San Francisco, CA
    Well hopefully I just have to change stickers.
    I don’t get the amp until Monday.
    hotraman likes this.
  4. hotraman
    Camas, WA
  5. Tim S
    Tim S Tele-Afflicted Gold Supporter
    Upstate NY
    The BCA will come with a sticker for the footswitch that’s a perfect match. I know because I went thru this last year when I got mine.
  6. Blrfl
    Blrfl Tele-Afflicted
    Northern Virginia
    GA-FCs are all the same internally; what the buttons do is determined by the amp.
    If you don't get a set of labels with your BCA, this is what's on them:
    MatsEriksson and McGlamRock like this.
  7. McGlamRock
    San Francisco, CA
    Thanks for the input. Hopefully it works out easy on Monday (when the amp arrives)
  8. Tim S
    Upstate NY
    @McGlamRock , How’s the new BCA? You can’t leave your thread hanging. :)
    SonicMustang likes this.
  9. McGlamRock
    San Francisco, CA
    How weird, I was logging in just now to give my review
    The amp just came yesterday and I played with it for a couple hours. It is a nice amp, the response is (like everyone says) very tube like. The coolest feature of the amp is the 'dual tone' that combines the "clean" and "crunch" channels. It achieves a beautiful, bright "sparkly" overdrive- perfect for that 80's & 90's country sound. I love that era of country music; so I really enjoyed that feature. The tremolo (tap activated, very convenient) and the reverb both sounded awesome.
    The "crunch" channel on its own, I did not find useful. I could dial in an ok driven sound. It did the 60's/70's rock thing ok. But nothing I couldn't do with a regular old tube screamer. The BCA didn't do the metal sound very well- which is what I associate the adjective, "crunch" with.
    The problem (and reason I am going to return it) is that the clean channel will always drive (just a little bit) when my pick attack is a bit too hard. That's cool for some things, but my actual tube amps give me more clean head room (Mesa Boogie F-30 & Bad Cat Trem Cat 30).
    Sadly I couldn't test the GA-FC because it turns out I do not own a stereo 1/4" cable- which is what the pedal needs to connect to the amp.
    The amp I bought is an open box, which with with the used GA-FC and tax, comes out to about $1000. Way too much IMO.
    I am inspired to shop around for a new overdrive pedal that does that 'sparkly driven sound' I mentioned earlier. I'm also considering a new tap activated tremolo pedal and new reverb pedal. I'm sure I can find a new pedal for all three of those effects for much less than $1000.
    MatsEriksson likes this.
  10. MatsEriksson
    MatsEriksson Tele-Afflicted
    Sweden
    I have that amp, and footswitch too. The stickers/label where gone and one can't get them, neither from Roland/Boss or anywhere else. I do use it for switching channels, reverb, tremolo, on amp. It's a tad unwieldy to try remember which switch does which... I have the GA-FC too...
  11. MatsEriksson
    Sweden
    If you buy the tone capsule Sparky Clean and plug it in, it will not break up anywhere in the clean channel. That's my main gripe with the amp too. That the clean channels break up, you can do on the dirt channel as well, with everything turned "low", and low input used. You can't get Fender Twin clean with it ever...;)
