G&L MFD single coil
Discussion in 'Just Pickups' started by Omar from ST, Sep 13, 2019.
  1. Omar from ST
    Omar from ST TDPRI Member
    Marbella, Spain
    I own a tribute Asat classic; I didn’t adjust pickup’s poles ever since I bought it.
    I’d like to get mellow tone, I’d appreciate some guidance.
    Thank you :D
  2. Gigante_Miguel
    Gigante_Miguel Tele-Meister
    San Bruno, CA
    You don’t need to mess with the pole pieces, these pickups are very responsive to the tone knob.
  3. Omar from ST
    Marbella, Spain
    They are, I totally agree. Thank you for your input :)
  4. brookdalebill
    Austin, Tx
    You might experiment with the pickup heights, too.
  5. sothoth
    sothoth Tele-Holic
    Kepler-186f
    Yes, do this.
    When you say you want a mellow tone do you mean yours sounds overly bright to you?
    Omar from ST likes this.
  6. Omar from ST
    Marbella, Spain
    The treble is bright, although I have all tone knobs down to zero. Also, I the bass is loud, especially the low E. Middle is perfect.
    How can I lower the pickup itself? By removing the pick guard? I haven’t tried that before to be honest. I’ll look it up. Many thanks!
  7. Dr. Bill
    Dr. Bill Tele-Afflicted
    Upstate, SC
    To lower the bridge pickup, use the three adjustment screws (one in front of the pickup and two behind). To lower the neck pickup, you have to take off the pickguard.
    Omar from ST and Bowpickins like this.
  8. Omar from ST
    Marbella, Spain
    Thank you Bill. :) I’ll try it this weekend.
    I mostly play jazz; in fact, I’m learning jazz.
  9. Bowpickins
    Bowpickins Tele-Meister
    Somewhere In TX
    I would look at raising the pickups a bit if you are trying to mellow out the tone.
    I have an Asat Classic S, and have messed with it to find the balance I have on mine. Also put MFD pickups in my Fender guitars.
    Bright treble is just part of the MFD's nature, in my opinion. I like it. I think it adds a nice clarity when the pickup is set right. Sounds like either a pickup height adjustment, or a pole piece adjustment would fix the bassy/boomy low E string.
    I tend to start adjusting pickups by first: getting the low E and high E string to be equal in volume (I tend to start on the bridge pickup with mine), by adjusting overall pickup height first. After that: I simply adjust the inside four strings to match output with the outer two strings, listening carefully to make sure each string rings out clearly and each string is equally heard. Readjusting pickup and pole piece height, as needed.
    Hope this helps! :)
    Joseph.
  10. DrASATele
    North of Boston
    I have an S500, a Legacy and an ASAT Blues Boy. My 95 S500 has MFDs in it, height is likely where you'll get the best results. As Bowpickins said that top end clarity is part of the MFD sound. I made several adjustments over the years to get the right blend. Good luck.
  11. Mr_Martin
    Mr_Martin Tele-Afflicted
    Cologne, Germany
    Jazz sound is good in my opinion
    Pechorin and Omar from ST like this.
  12. Omar from ST
    Marbella, Spain
    Thank you! I’ll start with pickup height.
    I ordered the S500 Strat then cancelled the order as I had to wait for 5 months. I was looking forward to playing it, but instead I bought a new amp :D
    Lovely! I usually use second position for jazz.
  13. POS Guitars
    POS Guitars Tele-Meister
    Los Angeles
    MFDs are bright. You can adjust pole pieces to equalize volume between strings. Overall height will affect brightness slightly. Closer to string should be more mellow on tone, but with higher output, and possibly lesser sustain. You could also increase the cap value. I’m not sure what cap you have, I think some tributes have 22nF. If that’s the case, try 33 or 47nF, or even 68, if you like.
  14. ahiddentableau
    ahiddentableau Tele-Meister
    Middle of Nowhere
    I agree with the last comment. Not saying you shouldn't try adjusting height. You should, and it might help some. But if your goal is to seriously darken up a pickup that sounds too bright when the tone knob is at zero, you need to change your tone cap to a larger value. The bigger the value, the more treble you can bleed off the signal. Most F-style guitars these days use 0.022uF. Try 0.1uF, the value Fender used on his first solid bodies. It'll get considerably darker when you pull down the tone knob. It might be just the ticket for you.
  15. Omar from ST
    Marbella, Spain
    Great info here, I appreciate your input! I'm ignorant when it comes to modding. I have three years of experience, so I'm still new :D cap = pot? If I'm going to mod it, I'd also go for 4-way control. Since it's my only guitar, I'll adjust both pickups' height and see the difference.
  16. guitarsophist
    guitarsophist Tele-Meister
    California
    I had an early U.S. made ASAT for a long while. I would say that rather than bright, the pickups are hi-fi. They are kind of like hi-fi P-90s. I could never quite get used to them, so I gave the guitar to a friend who loves it.
  17. Golem
    Golem Tele-Holic
    United States Of America
    MFDs are definitely bright. There's always a way to get a darker sound (e.g., rolling off the treble or using an EQ pedal). If that doesn't get you where you want they are sensitive to height adjustment.
  18. POS Guitars
    Los Angeles
    Cap=capacitor. It’s the component that rolls off the treble to ground via the tone pot.
    You will require some soldering knowledge to change it. But first, you should find out what value you currently have. Take the plate off, and take a pic of the cap, and post it here. We need to see the numbers and/or letters on it.
    4-way control, as in adding a serial configuration?
  19. Omar from ST
    Marbella, Spain
    Thank you! I will do that this weekend.
    My soldering skills suck :oops:
    Yes, adding a serial configuration. It seems complicated since it requires soldering.
  20. POS Guitars
    Los Angeles
    Soldering is easier than you think. You can just get a cheap soldering iron, you don’t need a fancy station. Get something bigger in the pen style soldering iron, maybe 45W, so can solder grounds on the pots (they start at 15W, I think). Watch some videos in YouTube - done. Don’t forget a soldering flux an solder.
    But start with some pics of what you have.
    Here is my 4-way switch schematic in a crude form. The switch part number I use is on the schematic (although, retail is $10).
