G&L Bluesboy Tribute Pickup Change
Discussion in 'Other T-Types and Partscasters' started by StuartJames, Jun 20, 2019.
  1. StuartJames
    StuartJames TDPRI Member
    Hi all
    Ive just ordered a SD Jerry Donahue for the bridge of my bluesboy. The stock neck humbucker will need to go as well as its to dark and muddy. I have a Gibson Burstbucker laying around so I’m wondering if this might work...
    Anyone put a Burstbucker in the neck of a Tele type guitar and had success balancing it with a single coil?
    Also, Can Seymour Duncan and Gibson pickups be mixed without experiencing phase issues?
    I’m planning on using 500k pots with a resistor so the bridge sees 250k
  2. Dr Improbable
    Dr Improbable Tele-Meister
    Wisconsin
    Will they fit? I wasn't sure you could swap out G&L pups for Fender specced ones.
  3. StuartJames
    Hmmm can’t see why they wouldn’t fit? Seems quite of few people have put the SD JD in bluesboys
  4. hamerfan
    hamerfan TDPRI Member
    Germany, Bavaria
    To match a neck humbucker with a single coil bridge is alway a PIA. First of all, low wound humbuckers with a3 magnet is an answer. Or Artie's De-mud mod helps with A5 humbuckers. David from Zhangbucker winds special wound humbuckers for Tele neck position.
  5. John C
    John C Friend of Leo's
    Kansas City
    ASAT Classic pickups are generally the same size as Fender pickups. Now the ASAT Specials have the large MFDs which are a unique size.
    Skydog1010 likes this.
  6. Beachbum
    Beachbum Friend of Leo's
    Sand Land
    Blues Boy Tribute with "Jerry Donahue" bridge and "Seth Lover" neck. No solder electronics with selectable cap values.
    Note: The Blues Boy Tributes ground wiring is the reverse of most others so the Jerry Donahue won't work with the stock humbucker without addressing that issue. My advice is to save yourself the hassle and replace both at the same time.
    Skydog1010, shupe13 and Nubs like this.
  7. StuartJames
    Any tried Jerry Donahue and a Jazz in the neck?
  8. StuartJames
    I would go for the Seth lover if $$$ wasn’t an issue. No sign of any used ones here in Oz
  9. bluescube
    bluescube Friend of Leo's
    Greensboro NC
    I would go with a P90 in a humbucker size for the neck
    Tonemonster likes this.
  10. bullfrogblues
    bullfrogblues Friend of Leo's
    Southeast Florida
    I paired a DiMarzio DP240 mini-humbucker with a Donahue bridge and they seem to match up quite well.
  11. Skydog1010
    Skydog1010 Tele-Afflicted Platinum Supporter
    North Carolina
    They fit and vice versa
