G&L ASAT Special and Hipshot Bender Question
Discussion in 'B-Bender Forum' started by Ray G, Feb 7, 2020.
  1. Ray G
    Ray G Tele-Holic
    New Jersey
    Hello All,
    I've been thinking about purchasing either a standard a Hipshot B Bender or a Hipshot Double Bender for my G&L ASAT Special and I'm hoping someone might be able to help with a question.
    There are retainers protruding off of the Hipshot unit that keep downward pressure on the B and G strings and with this in mind I'm wondering if the unit will actually fit on an ASAT Special? I'm thinking the ASAT Special's bridge (not a standard Tele bridge) may actually be in the way of the Hipshot string retainers... anyone happen to know one way or the other?
    There is also the option of getting the Will Ray Hipshot which doesn't have the retainers and definitely fits a G&L but it is chrome plated and my Special has a black bridge and a black metal pickguard & control plate so I'd want to get a black plated Hipshot unit.
    Thanks in advance.
  2. r1962j
    r1962j Tele-Meister
    St. Paul, MN
    I can't answer your question of if it will fit as is or not. But I can tell you that you can remove those retainers without any problem. I've been using HipShots since about 1983 and have never found a need for those retainers. When I bought a new unit for another guitar it had those so I left them on to see if they had any advantage for me. After a while I took them off, nothing changed.
  3. Texas Special
    Texas Special Tele-Meister
    Up The Junction, England
    Can't really help. But I've a Will Ray Hellebender on my Asat Special, works great. Can't say I've ever seen one in black.
  4. StrangerNY
    StrangerNY Friend of Leo's Gold Supporter
    Long Island, New York
    I've got a B/G bender on one of my Teles, and it's got the retainers with little bits of plastic tubing on them. The body is a poly finish so there's been no damage, but you might want to think twice if your guitar has a nitro finish.
    Get in touch with Hipshot and ask them directly! They're very helpful there - I contacted them about replacing the hip lever with a palm pedal, and they did the modification for me at no charge!
    I'm sure they'll help you out with your questions.
    - D
  5. milocj
    Michigan
    I don't know if the spring retainers have changed at all but the one I had in an ASAT Special fit fine. The one thing I found on mine was that the G&L bridge had a low enough exit point that the string retainer didn't actually touch the string which is a non-issue anyway.
    Have fun with it.
  6. 2 Headed Goat
    2 Headed Goat Friend of Leo's
    age 8
    https://www.premierguitar.com/articles/28385-will-rays-bottom-feeder-1982-gl-sc-2
    philbeck likes this.
  7. Ray G
    Ray G Tele-Holic
    New Jersey
    Thanks very much for each reply. Good to know that the retainers don't get in the way and/or really aren't needed if they did. That SC-2 either has an earlier version of a H-SHOT or they powder coated a Will Ray model specifically for Will. Thanks again for all the info... greatly appreciated!
    2 Headed Goat likes this.
  8. Don Miller
    Don Miller Tele-Afflicted
    Anchorage, Alaska
    You might call Hipshot...they are pretty helpful and I bet you're not the first to raise the question...Will Ray plays an ASAT....
  9. EsquireOK
    EsquireOK Friend of Leo's
    U.S.A.
    Strange. I have a black Hipshot B Bender, fully loaded up with benders and levers. I custom ordered it new about 7 or 8 years ago. It didn't have any such retainers, nor had I ever seen them before this thread.
