Fuzz pedal that works after a buffer?
Discussion in 'The Stomp Box' started by Kelsey, Aug 22, 2014.
  1. Kelsey
    Kelsey Tele-Holic
    Memphis, TN
    Are there any fuzz pedals that work well after a buffer? I use a buffer/interface at the front of my pedalboard and it works well with boost and OD pedals after it - good tone and dynamic response. Is there a fuzz that will sound good and dynamic and clean up well when used after a buffer?
  2. thinkdifferent
    thinkdifferent Tele-Meister
    Good ol' Europe
  3. RetroTeleRod
    RetroTeleRod Poster Extraordinaire
    Oklahoma, USA
    My Little Big Muff works just fine after a buffer. But cleans up...not so much.
  4. Stratburst
    Stratburst Friend of Leo's
    Toronto
    +1. That's a good value as well. Real bang-for-buck champion.
    On the other hand, many wahs (including the JB Crybaby and some Fulltone Clydes) have a buffer so you can use any fuzz after it.
  5. 1300 E Valencia
    Fullerton CA
    Um, I think you mean the other way around.
    Many fuzzes (especially germanium) do not like a buffered pedal in front of them.
  6. FilthyFur74
    FilthyFur74 Tele-Holic
    Yorkshire, UK
    I have all my fuzz before the buffer. The problem you face is that while Silicon mostly work ok after the buffer they generally don't clean up. Most Germanium fuzz will clean up but don't like buffers before them. You could maybe research if there's any hybrid Ge/Si fuzzies that can do both.
  7. RetroTeleRod
    Oklahoma, USA
    What about the Amptweaker Tight Fuzz ?
    Here's a bit from their site...
    "One of the important differences between the TightFuzz and most 'reissue' fuzz boxes is that with the addition of the Tight control in front of the fuzz circuit, the input of the fuzz circuit is effectively buffered from the guitar....but in a compensated way. A common problem with the original fuzz designs is that circuits with low output impedances like those in overdrive pedals and wah pedals, or the output of active pickups, can completely change the bias and gain structure. The result is often an odd sound or squeals, unusual feedback etc. The buffering in the TightFuzz simulates the impedance of a guitar, so that the fuzz circuit works in the normal way it's intended, and any low impedance circuit CAN be used in the loop or in front of the pedal."
    And the link...http://www.amptweaker.com/page/TightFuzz-by-Amptweaker-70.aspx
  8. 59 Restorer
    59 Restorer TDPRI Member
    Buffalo
    Pretty much agree but the Silicon Fuzz Face types like the MXR 108 do clean up with the guitar volume. But , the Germanium are better for that. My Red Dunlop FF sounds incredible with the volume rolled off on my Tele. I had the 108 and it would clean up but wasn't a sweet tone like the Germanium.
    Silicon Big Muff style fuzzes do not clean up.
    So I guess I am not really offering any help here.:confused:
  9. chris m.
    Santa Barbara, California
    Just use a true bypass fuzz first in your chain, before any buffer, problem solved.
  10. Tim Bowen
    Tim Bowen Poster Extraordinaire
    Atlanta/Rome, Georgia, US
    I guess BJFE effects became Bearfoot FX. I used to play some of the BJFE fuzzes. They're not typical fuzzes and aren't really placement-sensitive.
    http://www.bearfootfx.com/fuzz/
  11. aunchaki
    aunchaki Friend of Leo's
    Central New York
    Pete Thorn uses a BOSS FZ-2 on his big pedalboard (below) because it's not impedance sensitive.
  12. Hallo Spencer
    Hallo Spencer TDPRI Member
    berlin
    I'm waiting for the parts to build this pickup simulation here: http://www.muzique.com/lab/pickups.htm
    I have a Big Muff and a Wolly Mammoth sitting in a buffered parallel effectsloop (for blending in dry signal) and am not happy with the sound of the Mammoth after the buffer. The Muff also has some really harsh top end. I hope I can solve this with this little circuit here. Will check back here and tell you about results. Maybe it works. Clean Up will be difficult but you could try and build the update version (if you scroll down) and put the volume pot on the side of the box with a big knob so you can clean up with your foot.
  13. waparker4
    Philadelphia, PA
    The easy solution
  14. Otis Funkmeyer
    Otis Funkmeyer Tele-Holic
    Garfield NJ
    Try a Keeley Fuzz Head. Mine works well wherever I put it.
  15. artdecade
    artdecade Poster Extraordinaire
    Twangsylvania 6-5000
    Try the Boss Fuzz pedals.
  16. xtrajerry
    xtrajerry Doctor of Teleocity
    Lehigh Valley, PA
    The only Fuzz that I might have a problem with is the Keeley Broken Glass.. Haven't really tried moving it around the board.. my other keeley fuzz pedals are fine.
  17. simonsp
    simonsp Friend of Leo's
    England
    Steer clear of the FZ-3 though. It sounds horrible imo (and lots of other people's too i think. Every one for sale on eBay is like new - not a good sign.)
  18. Stratburst
    Toronto
    Point. Either way, those wahs are designed to work with a fuzz after them. Fuzz doesn't ordinarily work well post-wah.
