Fuse for Pro Junior? Slo-Bo, or no???
Discussion in 'Amp Tech Center' started by E5RSY, Feb 22, 2020.
  1. E5RSY
    E5RSY Doctor of Teleocity
    Georgetown, TX
    Just popped due to a power tube biting the dust. It is a 2A 250VP 30mm. I assumed it would be Slo-Blo, but the remnants don't look like it. Anyone tell me for sure?
    Thanks,
    Scott
    p.s. What is a good online source for these?
  2. Jon Snell
    Jon Snell Tele-Meister
    Jurassic Coast. UK.
    It should have an F2A or Fast Blow 2Amp 32mm or 1 1/4".
    Some other makers use T2A or Time Delay 2A. Screenshot 2020-02-23 at 09.04.10.png
  3. Jon Snell
    Jurassic Coast. UK.
    I have no idea for a source where you are but most electronic repair workshops will keep them.
    Don't use fleabay ... you won't know if it is fake or not and that could mean costing you a mains transformer as well!
    Mouser, RS, Farnell etc are reliable online sellers.
  4. milocj
    Michigan
    You should be able to get those at any good hardware store or Tractor Supply type place.
    Jon Snell likes this.
  5. E5RSY
    Georgetown, TX
    Thanks. Not sure which series that schematic applies to. It doesn't show mine. My amp is a 2006 v.2 (i.e. when they moved production to Mexico) and as I noted above, it calls for a 2A 250v unit. The "P" stands for "pulsating" time delay.
    Best,
    Scott
  6. Jon Snell
    Jurassic Coast. UK.
    I have check from 1994 up to current day, (well 2008 is where my manuals stop) and in all models; Fast Blow 2Amp for USA and Fast Blow 1Amp for UK. Both are rated at 250volts.
  7. Jon Snell
    Jurassic Coast. UK.
    They all show F type fuses the only one that uses T type is the Pro Reverb and that uses a time lag 2A for USA but it has a pair of 6L6s in it. The drawing to the right.
    E5RSY likes this.
  8. Jon Snell
    Jurassic Coast. UK.
    Screenshot 2020-02-23 at 20.02.27.png Pro Reverb fuses are T type
  9. Jon Snell
    Jurassic Coast. UK.
    It seems too obvious to look at the end caps. One end will either state F2A or T2A the other is makers mark etc.
