"Fuchs ODS reverb squeal"
Discussion in 'Amp Tech Center' started by telemonade, Jul 28, 2018.
  1. telemonade
    telemonade TDPRI Member
    Illinois
  2. Digital Larry
    Digital Larry Tele-Afflicted
    Silicon Valley, CA
    Wait till you're my age, it won't bug you as much. Seriously, I could not hear it. My son on the other hand said THAT IS LOUD.
    If you unplug the spring return completely, does it change anything? It's pretty easy to get replacement spring assemblies for about $20. But of course you don't want to waste $20 if that's not really the problem.
  3. telemonade
    Illinois
    Ha! I didn't think about the frequency of the ringing. Even when I unplug the RCA jacks of the spring reverb, it makes the ringing noise. One time I accidentally plugged the RCA jacks in backwards, the ringing stopped, and it made a buzzing noise.
  4. thunderbyrd
    thunderbyrd Poster Extraordinaire Silver Supporter
    central ky
    write to fuchs and see what they say.
    flyswatter likes this.
  5. JD0x0
    JD0x0 Poster Extraordinaire
    New York
    Contact Andy Fuchs, that's a pretty bad oscillation.
  6. telemonade
    Illinois
    I did write to Fuchs. Very nice, but couldn't diagnose without looking at it. They offered to fix it, but shipping and bench fees are pretty expensive for me right now. I'm guessing at some point I'll need to have a professional look at it.
  7. Digital Larry
    Silicon Valley, CA
    Here's my theory. Whether the spring is connected or not to the return doesn't matter. I think the output coil of the reverb spring is open. When you turned it around, the input coil (being good) made a connection which stopped the oscillation, though it buzzed. Different reverb springs have isolated or grounded inputs and outputs and different impedances. One thing you could do if you have an ohm meter is to check the resistance on the output. Normally I'd think it would be from the tens to a few thousand ohms depending on its design.
  8. telemonade
    Illinois
    Interesting, I like that theory. It still makes the ringing even when both RCA jacks are unplugged though. My first thought was to replace the reverb tank, but even with it unplugged from the amp, the ringing continues. The only time the ringing stops is when the reverb is plugged in backwards. I don't have an ohm meter, is there another way I could look into fixing it?
  9. Digital Larry
    Silicon Valley, CA
    The ringing (in my theory anyway) is because the input to the reverb return circuit is open. If it sounds the same whether the reverb spring output is plugged in or not. At that point it wouldn't matter whether the reverb spring input is plugged in or not.
    You can see if there's a number on the reverb pan that matches anything you can find here https://www.amplifiedparts.com/products/reverb_tanks
    and take a $20 (or so) gamble, which is what you might pay for a cheap ohm meter.
  10. telemonade
    Illinois
    I might go that route, thank you! Any other thoughts or suggestions are welcome.
  11. schmee
    schmee Poster Extraordinaire
    with no reverb connected it rings? you have a microphonic tube. The reverb circuit just enhances it.
    Wally likes this.
  12. JD0x0
    New York
    Sounds like the recovery/Mixer stages. Could be a bad tube, but I always assume people check the basics, when starting threads like this, and that's REALLY bad feedback for even a severely microphonic tube, IMO.. It could be a failed bypass cap in the recovery stage. I know in Fenders if the cathode isn't fully bypassed the reverb will start ringing like crazy, usually it starts with the dial around '6' though.
    Wally likes this.
  13. Wally
    It sounds like tech time, imho....unless you are willing to do some studying. That is a high dollar amp that deserves experienced tech work, imho.
