FSR BSB Reversed control plate club
Discussion in 'Guitar Owners Clubs' started by goldo, Feb 24, 2011.
  1. Still54
    Still54 TDPRI Member
    SoCal
    Hey Guys, First post. I've had an FSR BSB Reverse Control for about a year (1st Tele). Got a great price from Craigslist. Really like it, great wood pattern, awesome sound and very playable.
    Here's what I have done: Wrapped control cavity in copper foil, didn't do much but was easy and maybe some noise shielding. I also added a .047 Oil in Paper Russian cap, its big, but sounds good (I think better than stock). I also wanted a little more volume and tone control so I opted to replace the CTS pots with Mojo Vintage tapers, works really good.
    Here's and interesting item, I had noise in the middle position, thought something was mis-wired, Fender seems to always reverse wind their single poles. When I tested the magnets with a compass, they are wound the same. So in mine I don't get hum cancelling in middle. :(
    I have a Seymor Duncan Bridge Hot Rail (humbucker) but hesitant to install because would lose the single pole look. A friend put Lollars in his and really loves them, but kinda pricey. Wonder if I should just stay with the stock Pups? I play blues rock and use stereo Pro Juniors (great setup), getting most of my effects from the board.
  2. Philo
    Philo TDPRI Member
    I put the OV52 bridge pickup back in. To my ears, its got a little more upper mids and a tiny bit less "high high end" than the Nocaster; more of what I want a tele to sound like.
    Incidentally, the OV52 is closer to the ceramic bridge pickup that this came with, but sounds a little bit more vintage.
    I miss the hum cancelling in the middle position, but like the bridge sound better.
    Philo
  3. Ederson46
    Ederson46 TDPRI Member
    Manaus/Amazonas - Brasil
    Doubts Pickups Fender FSR
    Some sites say the pickups are Fender FSR Butterscotch Alnico III are true or ceramic?
  4. Ike286
    Ike286 Tele-Holic
    Michigan
    Once and for all. The pickups are CERAMIC!!!!!! Everyone keeps asking and we always tell them.... Sorry if i sound mad, im not. Anyway, they are overwound ceramic pickups and sound really good, personally, they aren't my thing, I'm looking for more vintage type pickups, (classic country type tones, brent mason brad paisley.. ) so I replaced them, BUT they are nice.
  5. Ike286
    Ike286 Tele-Holic
    Michigan
    I think we just play these teles more than any other guitar..... I've had mine for 15 months or so, and it is wearing. Oh well, I know a REALLY good luthier in my local area that works pretty cheap, just in case anything ever happens.
    Also, just as an interesting note... I finally got a 5 hole bakelite pickguard from stewmac. Not only does it look a LOT better, it fixed the static noises, that were so annoying.
  6. Obsessed
    Obsessed Telefied Silver Supporter
    Montana
    Ha, ya know you could be right about the playing quantity. I do a lot of strummin' in open G that I suppose could explain the wear.
    Does the 5 hole bakelite fit right over the stock eight hole without drilling?
  7. Ike286
    Ike286 Tele-Holic
    Michigan
    Mine didn't require any drilling, but it was a little bit close.. Some of the holes were just barely useable. But they went in ok, and its looks fine. I would think every guitar has the pickguard screws slightly different, so mine my be fine, yours could be perfect or horrible. My only complaint is that the stewmac guard is a teeny bit more shiny than the standard fender one. But it'll fade... and scratch. :)
  8. inspectorted
    inspectorted TDPRI Member
    Indiana
    I thought that ground screw made contact with a wire going to the bridge. Is that not the case?
  9. Guillermus
    Guillermus NEW MEMBER!
    SPAIN
    Hi!! I have just acquired this guitar a couple of weeks ago second hand, i believe mine is from 2011. It is wonderfull, plays and sounds great.
    I want to achieve the classic fender look, and I've already changed the tuners for vintage style klusons. I am considering to install a vintage style pickgaurd as well, a 5-hole bakelite black pickguard. But, my question is...
    WHAT can i do to make te neck pickup static since the vintage p.g. does not have two screws to hold it? Will i have to mount it into the body?
    advice and details will be very much apprecaited! thanks!
  10. emisilly
    emisilly Tele-Afflicted
    Suffolk, VA
    Yes you will have to mount the pickup to the body OR you can drill mounting holes in the new guard.
  11. Guillermus
    SPAIN
    THANKS VERY MUCH!!!
    But... Is there another way?? I mean i would rather mount the pick up to the body but... is it hard?? Has anyone done this?? thnx
  12. Flattop
    Flattop NEW MEMBER!
    Wisconsin
    New Member in Wisconsin
    Greetings from the Heartland. I brought my Fender FSR Standard Ash Telecaster (BSB) reversed control plate home from Guitar Center on Tuesday. Love this guitar, although I am letting it get acclimated to my studio before I run through a complete set-up. The frets need to be worked, as well as the neck relief and intonation, but I can already tell this one's a keeper.
    I'm glad to have found the FSR BSB RCP club and will post some better images soon...
    Cheers ;-)
    Flattop
  13. Ike286
    Ike286 Tele-Holic
    Michigan
    I gotta get some recent pics of mine to post. :)
  14. dad4
    dad4 TDPRI Member
    jackson Missouri
    New to the Club
    I picked one up on sat. I tried out $2300 les pauls, but I kept going back to the tele… However I was thinking on the way home something didn't seem right on the guitar, but it played and sounded amazing.
    So today I A/B's with my other mim tele and I noticed the reverse plate. I was freaking out thinking they screwed mine up os something. I started searching for something on the internet about them and found this site. Thanks for all of the info on here. Now i can sleep at night…..
  15. Ike286
    Ike286 Tele-Holic
    Michigan
    I put mine back to the standard tele style pretty quickly. It's much better that way. :)
  16. dad4
    dad4 TDPRI Member
    jackson Missouri
    HA HA We call Funk 49……. Funk 49,000, cause we play it all the time…..
    I love that song
  17. Ike286
    Ike286 Tele-Holic
    Michigan
    Aren't the Joe Walsh Songs just great though? :)
  18. Visceral
    Visceral NEW MEMBER!
    Schaumburg
    New to the FSR BSB Club!
    Been a member for a bit, but this is my first post. Hello fellow club members. I just received my FSR BSB today. Has a small ding in the back right side. For this reason I got this treasure for $382. I may relic her anyway. I was wondering if anyone else has relic'd this guitar. This finish is not really ideal, but I would be open to suggestions.
    A lot of folks have said that the pups that come stock are great. I wanted to wait and see and give them a chance. I am going to be switching the pups immediately. I am replacing them with the '51 Nocasters or some custom hand wound single coils from a great guitar man here in Chicago. The custom pups will pack a better punch. We shall see.
    I have a '52RI BSB Hot Rod. I love her. But for the price difference I was wrong to spend so much. I have a '72 RI Thinline with custom pups and a 5-way switch that is a MIM. Got it for less than $500. The MIMs are where it is at. Now, I can absolutely see the neck difference in the MIA Hot Rod. It plays so smooth. I am hoping my guitar guy can work the frets down a bit to get that smoothness on my new FSR.
    Overall, I may never buy a tele more than $500 again! Very impressed... Most everything sounds good through an original '68 Silverface Deluxe Reverb, though. Thanks father-in-law!
  19. dad4
    dad4 TDPRI Member
    jackson Missouri
    +1 on Joe Walsh…..he has big ole meat hooks...
  20. Ike286
    Ike286 Tele-Holic
    Michigan
    Hey, I have asked before, about tuners, and I'm looking at these ones....
    http://www.guitarcenter.com/Kluson-6-In-Line-Vintage-Tuning-Machines-102304565-i1472368.gc
    But I have heard so many times that they will need different bushings, and one guy on here said he bought them and put them on his FSR no problem. I really like the look, and the feel, I've always liked better, and restringing is much easier to me with the vintage slotted tuners. Again, I have asked before, but not in much depth.
