From the Ashes of a Great but Unloved Amp...
Discussion in 'Shock Brother's DIY Amps' started by shortcircuit, Nov 20, 2019.
  1. shortcircuit
    shortcircuit Tele-Meister
    North Carolina
    The GA-100 is no more, but Dr. Frankenstein has been busy...
    Just need to hook up the transformers and the NFB/presence circuit. All octal tubes...
    ...except for this little guy. There will be a voltage divider going to the grid of the second triode. I'll clip in a 1M pot and figure it out once everything's hooked up.
  2. mabinogeon
    mabinogeon TDPRI Member Silver Supporter
    Upper Michigan
    I have three quick questions, if you don't mind:
    1 - Where do you get that pre-drilled turret board? None of my usual vendors have it.
    2 - Where do you get that clear lead insulating tubing? I use scraps of stripped wire, but am running low.
    3 - What are those spirally looking things I see on a couple of the resistors and caps? Solderable lead extenders? Where do you get those?
    Thanks much for your time
  3. shortcircuit
    North Carolina
    amplifiedparts.com
    https://www.ebay.com/itm/5M-PTFE-F4-Teflon-Tubing-Rigid-Pipe-ID-0-3mm-1-3mm-High-Temperature/331536271458
    I got the 0.7mm, 0.9mm, and 1.1mm ID tubings rated for 600V. I have all of my bases covered with the three sizes.
    https://www.tdpri.com/threads/5f2a-ish-with-tremolo.983519/#post-9406820
  4. shortcircuit
    North Carolina
    All done.
    I set the voltage divider in front of the second triode at 470K/470K, boring. It doesn't seem need a bright cap across the top half. I'm trying to decide to whether to use a 6SL7 or a 6SN7 for the phase inverter. I had designed it so either tube can be used.
    ecoast and Snfoilhat like this.
  5. mabinogeon
    Upper Michigan
  6. jtcnj
    jtcnj Tele-Holic
    Brick, N.J. USA
    Nice work; this is like I'm in Little League watching the pros play.
    On that insulated tubing, the (S) is the 600v, and the price listed is for a 5m length?
    If you were to only buy 1 size, which would you / most versatile? I am thinking the one suited for the orange caps in your pics?
  7. mabinogeon
    Upper Michigan
    I just ordered one of each size that he recommended above. Was $12 total for 5 meters of each size.
  8. shortcircuit
    North Carolina
    The medium orange drops required the 0.9mm tubing, and the big ones, the 1.1mm. I also use a lot of solid copper wires for various duties. The 0.7mm fit 24ga, 0.9mm fit 20ga, and 1.1mm fit 18ga.
    jtcnj and mabinogeon like this.
  9. CCK1
    CCK1 Tele-Meister
    North Georgia
    Very Nice!
  10. shortcircuit
    North Carolina
    Definitely 6SN7 for the phase inverter. It sounded much more smooth, plus, I don't need the extra gain of the 6SL7 because of the high gain preamp. The 6SN7 can handle a lot more plate voltage too.
    I redid the power supply. Initially, I followed the GA-100 layout, running the plates after the choke, but that was more of a Hi-Fi thing. The voltage coming out of the rectifier was lower than I had expected. I wanted a little more juice to the plates and screens, so I hooked the plates to the node before the choke, and the screens to the node after the choke. I got rid of the 2.2K resistor to raise the voltage to the preamp tubes to the level I had calculated.
    Final schematic with voltages.
    The plate dissipation of the 6L6's were 20.5W each, and the clean output power was 35W at 440Hz.
    Oh, yeah, the power transformer is a Hammond 273BX and the output transformer is a NRE Kustom 4.5K PP surplus job I picked up from Ebay a while back.
  11. bcorig
    bcorig Tele-Afflicted Silver Supporter
    Chino Hills CA
    Dude, my brain hurts.
  12. David Barnett
    Why do you lace your ground bus like that?
  13. shortcircuit
    North Carolina
    Using multi-strand ground bus is like a multi-core processor in a computer. It allows the power supply to ground faster, thereby reducing hum...
    I saw a build a while back with the ground bus laced like that, and I thought it looked cool. :oops:
    SacDAve and CV Jee Beez like this.
  14. sds1
    sds1 Tele-Afflicted
    Orlando, FL, USA
    Hmm interesting, I hadn't heard this before. Can you elaborate, or do you have a link to a technical discussion on the matter?
    My assumption would be that stranded bus wire would perform the same as solid when the total mass of the copper is equal.
  15. RottenTheCat
    RottenTheCat Tele-Holic
    Drambuie, Africa
    I'm interested in the switching of the cathode bypass on the first preamp stage. You're choosing to ground the capacitors with the switch, leaving the other in place with the 470k resistor - which without doing any math, should effectively eliminate it. So ... since its more complex than just switching, is that for pop reduction when switching?
    Mexitele Blues likes this.
  16. shortcircuit
    North Carolina
    I was being silly.:D
    King Fan likes this.
  17. shortcircuit
    North Carolina
    Yep, the 470K resistors are there to prevent popping when flipping the switch.
  18. sds1
    sds1 Tele-Afflicted
    Orlando, FL, USA
    Dude it's all fun and games but next thing you know everyone is using stranded bus wire. Once it shows up in some build thread it's too late, you'll need to run with it! :lol:
    shortcircuit and King Fan like this.
  19. King Fan
    King Fan Friend of Leo's
    Salt Lake City
    :lolol: Yeah, the current fluxes faster if the electrons have a choice of two wires and all intersections are like roundabouts instead of stop signs. :D
    Seriously, I saw this first on Doug Hoffman's builds...
    It's pretty, true, but also "tidy" to build: consistent, fast, and easy. Doug demonstrates here:
    Notice you can use fine, pliable wire to build a sturdy bus (Doug uses 24ga), and you get easy but solid wraps around the turret -- these are not component leads you might need to replace. Plus they end up at the bottom of the turret, leaving room for leads above and on top.
    SacDAve likes this.
  20. sonicsmitty
    sonicsmitty Tele-Holic
    Clarksville, TN
    Very nice looking work. You've got photos and schematic. You forgot the audio clips. :D
