Fretboard overhang at heel
Discussion in 'Tele Home Depot' started by Glen Smith, Jun 8, 2012.
  1. Glen Smith
    Glen Smith RIP
    Is there a standard measurement of the amount of fretboard overhang at the heel of a 22 fret tele neck?
  2. LesterCorncrake
    LesterCorncrake TDPRI Member
    Lincolnshire, UK
    Standard 22 Fret
    A fingerboard with 22 frets is considered the industry "standard" for the last few decades and sports the typical 1/4" overhang off the end of the heel. This has always been the standard spec for our Vintage Modern series.
    http://www.warmoth.com/Guitar/Necks/FretboardExtensions.aspx
  3. Casual_Reader
    Casual_Reader Tele-Holic
    Ohio
    I haven't taken a pair of calipers to a 22 fret neck, but based on all the fender PDFs that I've scaled to size, it's consistently 0.20".
  4. Glen Smith
    Glen Smith RIP
    Thanks fellas.
  5. Guitarnut
    Guitarnut Friend of Leo's
    I use the Stew Mac fret scale and I've always used the 23 fret mark as the cut off for the FB extension. Works fine.
  6. nosmo
    nosmo Friend of Leo's
    Lake Jackson, TX
    I think you can go 'till it hits the neck PU, but after that you'll have a problem :D
  7. Glen Smith
    Glen Smith RIP
    The reason behind my question: I bought a tele neck on ebay but the previous owner rounded the heel as if he wanted to install it in a Strat. I want to re-establish the original lines to the heel so I will have to make a straight cut across the neck heel without getting into the fingerboard. Then I will glue on a piece of maple and finally shape it to original specs.
  8. Mojotron
    Mojotron Poster Extraordinaire
    Seattle
    Yep - I've measured the one I had at .2".
  9. nosmo
    Lake Jackson, TX
    If you trim the neck like that, can't you just add your maple and make it match the length of the regular tele neck template? I suppose if the fingerboard is not long enough to cover it, you could add wood to the pocket instead and hide it with a pickguard.
  10. Glen Smith
    Glen Smith RIP
    He didn't do a perfect job of rounding the heel. That is why I will have to cut it straight then glue in some maple, cut to the correct length then just round the two corners.
  11. nosmo
    Lake Jackson, TX
    Yep - I got that. Sounds like a good method for fixing it.
  12. Casual_Reader
    Ohio
    thanks - good to have it confirmed.
    the 87 am. std. strat neck blueprint that's been scanned and posted left that unspecified... with no way to math it out unless you already know the nut to butt length.
    odd that they'd leave a critical measurement like heel position out.
  13. spook69
    spook69 Tele-Holic
    Devon, England
    Nope, you just need an Esquire then.:D
