Fretboard Dots - Brad Point??
tkmclaughlin
Armonk, NY
Hi all. I’ve built a few fretboards so far and am still in learning territory. I also don’t have the most precise drill press (I’ve got a Harbor Freight model which a guy once made me laugh when he called it a “boat anchor”). Anyway, I’ve struggled getting the process right for drilling fretboard markers. I buy the ones from StewMac and they are pretty thin (1.27mm). You don’t have much room for error before you go too deep with the hole, and when I sand flush sometimes it hollows out a part of the dot. My question is whether I’ve been using the wrong drill bit. My 1/4” Brad point bit does not leave a flat cavity. Obviously it leaves a dot in the center, but more importantly the shape of the flutes leaves kind of like a concave frisbee sort of shape (with a hole in the middle) where there is like a raised disk in the center of cavity sloping down toward the outside of the hole. So even though I set my drill press to drill the right depth, it’s actually raised up a bit in the middle and the dot sits too high in the cavity. So then I try to go a little lower, and inevitably go too low.
Is there, maybe, a flat-bottomed drill bit I should be using that would more accurately let me measure my holes?
EDIT - maybe I should use an end mill bit?
Sorry for the dumb question but any advice would be helpful!
tkmclaughlin
Armonk, NY
Thank you for the Brad point bit recommendation. I kind of suspected that mine might be of poorer quality in that they leave that dome shape. I will look into improving my bit set.
Dan Miller
Thousand Islands, New York
Trivia time :cool: - a lot of folks don't realize how long they've been around. The original patent for them is from 1886. Here is a set I have meant to be used in a bit brace.
oldunc
California
Forstner bits are guided by their rim once they're started, so it would actually be possible to start a hole with a regular bit and finish it with a pointless one, I wonder if anyone's done anything with that? Never had a problem with the point, myself, but it could happen.
novakane
I have an adapter and use some more modern forstner bits in a very old Stanley 923 for routing out cavities in guitar bodies.
