Fret Leveling
Discussion in 'Other Guitars, other instruments' started by The Angry Possum, Sep 11, 2019.
  1. The Angry Possum
    The Angry Possum Tele-Holic
    Staten Island NY
    Hi, Can I level frets with an 8" leveling block, or does it have to be longer. Or can it be shorter than 8".
    Please post any links if you have some I can look at to purchase.
    Vince
  2. boredguy6060
    boredguy6060 Poster Extraordinaire
    Sou Cal
    Yes you can use an 8 inch block.
    Go to StewMac they have many size blocks as well as videos on how to level frets.
    Good luck,
    The Angry Possum likes this.
  3. Ricky D.
    Ricky D. Doctor of Teleocity
    Raleigh, North Carolina
    Check out Ron Kirn's fret leveling post on Tele Technical. All you need and nothing you don't.
    The Angry Possum and Macrogats like this.
  4. Macrogats
    Macrogats Friend of Leo's
    Auckland, New Zealand
    Echo this. As Ron suggests hunt around for some marble type bench off cuts or similar. I used a 12mm tile off cut glued to a piece of 2 x 2 - flat as anything can be. To be safe I used 400 grit double taped to it and it works perfectly. No need to spend exorbitant amounts of money elsewhere. ;)
    Ricky D. and The Angry Possum like this.
  5. Luthi3rz
    Luthi3rz Tele-Meister
    AZ
  6. G.Rotten
    G.Rotten Tele-Afflicted
    CoolsVille
    Over the years I've acquired a few tools, so I've used a flat (bastard) file, & radiusing blocks. Both get the job done, one requires you to pay a little more attention.
    Regardless of what tool I start with I finishe the job with a Dremel & polishing wheel with fretboard guard.
    Recently I bought this guy & it's handy. 3 different grades of paper glued to a straight edge.
    https://www.amazon.ca/iLuiz-Leveling-Sanding-Leveler-Luthier/dp/B07BHCT6ZV/ref=sr_1_1_sspa?crid=1NCQRMJAJWVGU&keywords=fret+leveling+beam&qid=1568246096&sprefix=Fret+le,aps,183&sr=8-1-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEyT04wREVER1YwU1dSJmVuY3J5cHRlZElkPUEwODkzODk3MzIwWFRIMTZTUjlLTyZlbmNyeXB0ZWRBZElkPUEwNTU5MTU2MTdJR1ExVzA1NDJHNSZ3aWRnZXROYW1lPXNwX2F0ZiZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU=
  7. Irondog
    Irondog Tele-Meister
    San Francisco, California
    I found this to be very enjoyable watch, he uses 16 inch. great video.
    The Angry Possum and Deeve like this.
