Fret Leveling Block
Discussion in 'The DIY Tool Shed' started by bottomfeeder, Dec 11, 2017.
  1. bottomfeeder
    bottomfeeder Tele-Meister
    Manteo, NC
    Any suggestions for a quality, inexpensive leveling block to use with adhesive sandpaper? While I'm asking, what type and grit sandpaper do you recommend?
  2. rogb
    rogb Tele-Afflicted
    London, England
    Find your nearest kitchen worktop cutting/fitting service and ask them for some Granite offcuts with a polished surface on one side. Maybe 2-2.5" x 10-12"x 0.75" thick ?
    I went to one here in London and they told me to help myself in their waste skip (USA:dumpster?), I grabbed a few pieces and they wouldn't take any payment.
    Work a treat and you will have a spare if you drop one and break it:cool:
    Mat UK likes this.
  3. bottomfeeder
    Manteo, NC
    I'm surprised that the Corian has a "true" flat surface
  4. telemnemonics
    Some suggest granite countertop scraps rather than corian, or some of the synthetic stone.
    Some use a carpenters level either box aluminum or I beam aluminum.
    Corian is actually flexible and you may not get a straight result.
    Theoretically the granite is milled dead flat and is certainly not flexible.
  5. rogb
    rogb Tele-Afflicted
    London, England
    Sorry you're right I just checked and it is granite, but I'm pretty sure Corian will be fine if it is thick enough.
    Ron Kirn says it's OK, which is where I must have heard it from.
    http://www.ronkirn.com/ssb-the-neck/
  6. xafinity
    xafinity Friend of Leo's
    my Mom's basement
    liquid finds its own level as it drys
    corian is pretty darn level
  7. charlie chitlin
    Kimberton
    Mine's a granite sink backsplash.
    They cut it in half for free.
    I resisted the urge to pass the 2nd one on because I'm pretty sure I'll eventually break one.
    For the time being I have one with 400 and one with 600.
  8. guitarbuilder
  9. bottomfeeder
    Manteo, NC
    Thanks for the input guys, I'm not doing a full refret on my tele, just maintenanceence leveling. What's a good length for that application?
  10. daddyplaysbass
    daddyplaysbass Tele-Afflicted
    Chandler Arizona
    I have an aluminum block, 6" X 2" X 1" tall. Will that work? What grit does anyone suggest?
  11. charlie chitlin
    Kimberton
    6" sure doesn't seem long enough to get a good level.
    Mine's 16
    S-arm likes this.
  12. Davecam48
    Queensland Australia
    That's what I did, the piece was free but I paid them a couple of $$$ to level and polish all surfaces to a high degree. Works very well.
    DC
  13. Tone Revival
    Tone Revival TDPRI Member Vendor Member
    Israel
    Depending on the thickness and length of the glass, it might deform under its own weight. You'll need a rather thick piece of glass in order for it to stay true.
    Regarding the sandpaper, for dressing worn frets I usually use 220-400 with my leveling beam (Although you can start with 120 if you have a lot of material to go through...). For newly installed frets I start with 320-400.
    I would than use up to 2500 grit along the neck by hand, followed by 0000 steel wool across the neck.
  14. LutherBurger
    LutherBurger Friend of Leo's
    NYC
    I use half of a 36" marble threshold tile from Home Depot. It cost less than $10.
    charlie chitlin and jvin248 like this.
  15. guitarbuilder
    You adhere it to another piece of sheet goods to support it.
  16. jvin248
    jvin248 Poster Extraordinaire
    Lions & Tigers oh Mi !
    I have granite counter top off-cuts I trimmed with a tile saw and a roll of emery cloth from Harbor Freight 240grit.
    1x16inch and 1x20inch.
    The marble threashold is a great option. Avoid 120grit as it gouges too much that you are fixing later.
    Also, for better results you'll want to build a Vinson neck tension system or buy the Stew Mac system. That ups the leveling game quite a bit.
  17. Tone Revival
    Israel
    Guitarbuilder, indeed!
    I will organize an expedition to find my lost common sense...
  18. Mat UK
    Mat UK Tele-Afflicted
    London, UK
    Out of curiosity what was the name of the kitchen company? I live south east, all the kitchen companies I’ve visited have been unhelpful!
    rogb likes this.
  19. rogb
    rogb Tele-Afflicted
    London, England
    http://www.eurosstone.com/
    It's on the North Circular near Staples Corner.
    It was a few years back so I can't vouch for their current friendliness, but they were then.
    In fact, I think I have recommended them to people who actually needed worktops, so they must have been OK:cool:
  20. SecretSquirrel
    SecretSquirrel Friend of Leo's Ad Free Member
    PNW USA
    I got this 18" length of tile at a recycled building materials place:
    I use 'glue stick' (spray adhesive would be better) to adhere sandpaper:
    It worked out well, long enough to cover all the frets on most fretboards.
    For crowning, I filed a "V" into a sharpening stone:
    Funky but works pretty good, as in 'better than nothing' which is what I had at the moment. I filed two V's, one for taller frets, a shallower one for low/worn frets.
    (You can see one side of the V is a different grit, a minor issue I'll rectify later with another stone; meanwhile I just reverse the stone every few strokes to even things out.)
    ONE EDIT: If I file a notch into another whetstone, I think I'll try a round file instead of triagular, for a rounded crown.
    Hope that helps some, good luck!
