Fret Erasers
Discussion in 'Tele-Technical' started by WrayGun, Feb 1, 2021.
  1. triple_vee
    triple_vee TDPRI Member
    Seattle
    2 sided nail polishing file FTW. Coarse side then fine side.
  2. Cpt.Blues
    Cpt.Blues TDPRI Member
    Moorpark, CA
    The Mr. Clean Magic erasers need to be wet in order to work. Probably not a good idea on the fretboard.
  3. bsman
    bsman Friend of Leo's
    Santa Clara
    Since I'd be taping off the fretboard anyway, does that really matter???
  4. Henley
    Henley Tele-Holic
    Beach Cities
    I try not to use water when I do fretwork. Never used these erasers...steel wool is still my favorite, it makes quick work of it...and if you know how to prep correctly...it's not messy.,
    I just bought a pack of the Japanese Hosco variety to test.
  5. Robert Graf
    Robert Graf Tele-Meister
    Broadview Heights, OH
    I don't know where you got that price, but I think I paid around 40 bucks for a roll of 1000 grit, which I use a decent amount of, although the stuff lasts a long time. I don't remember what I paid for the sheets, but it was much cheaper than buying any of the kits or assortments, and I use it on metal, wood and plastic. The sheets I buy are probably 9 x 12.
  6. moosie
    Western Connecticut
    Are you buying actual, branded Micro Mesh? Micro Mesh doesn't come in 1000 grit. They use their own grading system. The regular MM grades range from 1500 - 12000. AO and MX types have their own ranges, and are used for specialized purposes. Nowhere is there a grade 1000.
    I got that price from the manufacturer's site: https://micro-surface.com/product/micro-mesh-rolls/
    If you're getting a knock-off from eBay for cheap, that might explain the need to go through so much. MM is not just 'very fine sandpaper'.
  7. Robert Graf
    It's not counterfeit. It's Micro Mesh. I've been using it for over 20 years. I picked it up of the internet, but not through eBay. I think it was from some auto body shop over 10 years ago, so they were probably just clearing out what they had around. The AO stuff is aluminum oxide, mostly for plastics, and the MX line is for metal polishing.
