Jmfranc
Have a couple nice maple necks that were just completed and now time to spray with nitro.
Doing another strat neck and want to avoid problems I’ve had in the past that’s mainly the tint nitro layer not being even on the fretboard. On either side of the frets I get either a “shadow” where the tint is lighter than the rest of the surface or it ends up heavier on one side. I’ve tried vertically flipping my neck after each coat and still had the issue. Any tips on how to get a even coat?
I use stewmac nitro that I tint using their amber dye. I’ve used cans, prival sprayers, and a paint gun w air compressor. I’ve used the lightest possible coats which took me at least 7 or 8 coats to get the color I want and it was still a very thin finish when it was done. I’ve considered wiping on the amber dye mixed with acetone so I could get it even and then just spray clear but it doesn’t have the right look.
And spraying with no frets on the neck worked well until I pressed the frets in and the nitro cracked (massive crack between tuner holes when pressing in the bushings). I think I’ve tried it all. I’ve painted over a hundred bodies but the necks are killing me.
