(Free) software for drawing guitar wiring diagrams, circuit layouts...
Discussion in 'The DIY Tool Shed' started by bancika, Feb 6, 2017.
  1. bancika
    bancika TDPRI Member
    Serbia
    Cool...out of curiosity, why are you using solder pads instead of "Trace Cut" components on the vero board? I now have some tools to analyze the circuit and they will not work properly if you misuse components like that. For example, there is "Highlight Connected Areas" mode in the config that will highlight traces on the vero that are jumpered together, but will honor the cuts...or you can create a netlist and see in text form the component nodes that will get connected.
  2. awasson
    awasson Poster Extraordinaire Silver Supporter
    Vancouver
    I use the solder pad because visually it looks more like a cut. Maybe I can edit/configure the cut to work better but I haven't been able to as of yet. I also can't get change the colour of the jumper wires. I am using 3.50.0 so perhaps the new version will improve on this. I'll give it a shot and let you know.
    Cheers,
    Andrew
    EDIT: I just checked and it looks like I used solder pads under the OpAmps but the others are using the Trace Cut component. Reason I used pads under the OpAmps is because the pads have better definition but I’ll change them out for the proper trace cut components so that the software can analyze the circuit.
  3. Norris Vulcan
    Norris Vulcan Tele-Afflicted
    Bancika, as a long-time user of your DIY Layout Creator, you are a legend.
    This new one looks good, too.
    Thanks for your work, much appreciated.
    awasson likes this.
  4. nosmo
    nosmo Friend of Leo's
    Lake Jackson, TX
    Does anyone have a solution for opening this on a Mac? I get the "damaged" dialog box and can't seem to override the security. I have tried control-click to open as per Apple help with no success.
    24 track likes this.
  5. 24 track
    24 track Doctor of Teleocity Ad Free Member
    kamloops bc
    same here
  6. awasson
    Vancouver
    It works fine on the Mac but you do have to turn off Mac’s heavy handed security temporarily. You have to turn it off via the shell for the first time you run it and then you can turn it back on. We discussed this a couple of times in TDPRI. I’ll find the relevant info and link it.
  7. awasson
    Vancouver
  8. nosmo
    Lake Jackson, TX
    Thank you. That worked.
    awasson likes this.
  9. SacDAve
    SacDAve Poster Extraordinaire
    Rocklin Ca.
    I have it running on my Mac, My wife found the solution, you have to disable something in the security to let you download second party app's, I'll ask her when she gets home hopefully she will remember If she finds it's I'll post it. I upgraded my mac I was getting the same Java thing never worked i really missed DLC. BTW be about 4 hours.
  10. SacDAve
    Rocklin Ca.
    Didn't notice you got it solved
  11. AAT65
    AAT65 Poster Extraordinaire
    West Lothian, Scotland
    Just got DIYLC running on my Mac and really need to say Thank You!
    It’s an excellent and very useful piece of software, and must have taken me all of 30 seconds to work out how to do what I wanted — very good work! You are a friend to all guitar-playing mankind!!
    awasson likes this.
  12. I_build_my_own
    New York
    I am using DesignSpark to draw and route schematics. It is free and easy to use, even creating your own components is fairly straight forward.
    It creates Gerber format, which I then open in CamBam (not free but also not outrageous for a hobbyist) and make to tool path and hit the baby CNC with the Gcode.
    A PCB has just become a more elaborate guitar headstock inlay.
    Schematic
    Routing
    Gerber imported into CamBam
    Postprocessing and tool pathing (with errors still)
    Making some dust
    Final product
    awasson likes this.
  13. Asmith
    Asmith Friend of Leo's
    East Yorkshire, England
    I've just changed PCs and installed the nescessities for my personal pedal designs. Audacity for recording dry .wav files of my playing, LTSPICE for circuit design and simulations and of course DIYLC. Wish I had updated sooner, there's tonnes of components I previously drew up using the shapes and other components. The twisted wires and all the new electromechanical stuff would have been great in my amp design and the audio transformer in my octave up/preamp.
    Anyway thank you for the constant updates.
    awasson likes this.
  14. brogh
    brogh Moderator Staff Member
    Teleland
    Admin Post
    Wonderful !
    thanks for sharing !
  15. mcatueno
    mcatueno TDPRI Member
    argentina
    I've just registered here just to say THANK YOU BANCIKA for such an amazing job!
    awasson likes this.
  16. velja
    velja NEW MEMBER!
    Pančevo, Serbia
    Bravo Bancika.
  17. Euphonica
    Euphonica Tele-Meister
    New Orleans, LA
    I am a total newbie and am trying this stuff out for the first time. Apologies if I am asking dumb questions.
    This is awesome!! But it's not working for me, I cannot switch between component options. It says to "right click" but I am on a Mac, and that usually means ctrl+click. But I tried everything and can't get options.
    I am trying to put in jaguar switches, and I've hit a wall. Any way to get a right click on a Mac? I'm on Catalina.
    EDIT: switched to a Windows box (which I hate, if someone can get this to work on Mac I’d love it) so now I have a right click, but now I can’t find roller pots. Where are those?
    2nd EDIT: there are no roller pots. Oh well.
  18. Asmith
    Just use the dpdt toggle switch and the standard potentiometers. The actuator doesn't really matter and as far as I'm aware there are no actuators in the software.
    You can change the size of the potential/rotate it by double clicking the component which will bring up an options menu. You can do the same (double click) on the switch to rotate the switch.
  19. Euphonica
    New Orleans, LA
    Hey thanks a lot for the reply! I had to switch to a Windows box (which sucks!) in order to get the DPDT switch. I don't understand why the Ctrl+click doesn't work as a right click.
    Now I am in wiring hell and have zero idea what I'm doing. I tried to make a diagram that could be submitted for correction, but I'm totally lost at the lower switch plate switches. I'll be asking for help very soon... I wish I had gone to school for this stuff.
    Sorry for being emotional, computer trigger me.
    Asmith likes this.
  20. MirageIndigo
    MirageIndigo TDPRI Member
    A skosh north of Boulder, CO
    What's your core issue? I've used DIYLC on osx for a while when laying out amps and it just kinda works. You do need to disable the security to get the install working, right click on OSX is something like ctrl+click. Or you can just plugin a regular external mouse.
    Note that the roller pots are just pots with a roller attached to the shaft, right?
