cryptonomicon
Have been mulling over an amp design - as one does when one reads RobRob's site a little bit too much. What started as the idea of a two channel amp with a AA1164 Princeton Reverb on one channel and a 5E3 Deluxe the other, tone king imperial sort of thing, has morphed into replacing the normal channel on an AB763 Deluxe Reverb with a 5E3 pre-amp and tone stack.
Conceptually can you see any major problems?
Basically it is the tone stack and first two preamps of a 5E3 up to and including the coupling cap on V2A and plugging that into the input of the 3.3M mix reverb mix resistor - al-la the robrob normal channel mod. And then putting in a Lar-Mar trainwreck 2 Master Volume and Negative Feedback Mod.
The weird bit, and am still thinking about it, is a blend between Channel 1 and Channel 2 so that you can dial in some tweed dirt into the blackface cleans. I am seeing a mid scooped, mid pushed thing going on here.
It makes sense to me, but then I don't know enough to know what I don't know.
