For my next trick: Sawing the Lady in Half. With a twist.
Discussion in 'Tele Home Depot' started by Peegoo, Dec 13, 2019.
  1. Peegoo
    Peegoo Tele-Holic
    Alternative thread title: How to turn a two-piece body into a four-piece body
    This is something I've wanted to try for many years: resaw a tele body down the middle, hollow it out, and glue it back together.
    I've built hollow and chambered guitars in the past, but they were all built in stages, with chambering done before gluing up the 'sandwich'.
    This approach today was a little different because I was starting with a reasonably completed Tele body. I've had a pine body hanging in my shop for several years collecting dust, so I decided to make it dustier. It's yellow pine, about three pounds, made from a two-piece glued-up slab. All the machining was done (routs, drilled holes, and perimeter round-overs). I used a template from a '53 Telecaster for it.
    I have no band saw, so it was get out the ripsaw, clamp on some sticks to serve as saw guides, and have at it. I didn't go down the center because I wanted to leave plenty of meat in the top surface of the neck pocket.
    There are two 1x2s on each side of the body, held in place by clamps. The gap in the boards is 3/32" to accommodate the blade and kerf of the saw which is 1/16".
    As I cut through the wood I had to move the clamps around to prevent sawing through them. You can see how many years this body's been hanging in the shop by how nicely darkened with age it is.
    It was easy going because the pine is fairly soft, but the grain still had a tendency to deflect the cut so a few times I had to switch sides that I cut from to help keep the saw tracking straight.
    It worked pretty well.
    You can see the saw marks in the wood, as well as the shadow where the bridge pickup rout is...because the wood is paper-thin there.
    Next step...get out the router and hog out some wood.
    More to follow.
  2. Maroonandwhite
    Maroonandwhite Tele-Meister Silver Supporter
    Moscow, TN
    That’s awesome! Can’t wait to see the progress.
  3. Peegoo
    Peegoo Tele-Holic
    Cheers!
    There have been some weirdo guitars that emerged from my lab, but this one will be fairly pedestrian compared to those other things.
  4. Deeve
    Deeve Friend of Leo's Silver Supporter
    Ballard
    I've wanted to do this to the avatar guitar, which is great, but heavier than I'd like.
    Props for the decision to keep the neck-pocket safe.
    Peace - Deeve
  5. Peegoo
    Peegoo Tele-Holic
    Cheers, Deeve.
    It really does not matter that the saw cut is off center because I will be shooting color on this one.
  6. Davecam48
    Queensland Australia
    IMGP7795.JPG IMGP7796.JPG IMGP7803.JPG I understand that this is an exercise in "What if I....?" but there are other ways of achieving a lighter stronger guitar with out all the "hogging out" as you guys call it, and all the hard work. Still, if it uses up an old neglected body (sounds like me!") and you have some fun doing it .....who am I to criticize? :lol:
    DC
    Macrogats and old wrench like this.
  7. jfgesquire
    jfgesquire Tele-Holic
    Lake View
    Ooooh!!! Can I make a suggestion!?!?
    Do the reverse of the George Harrison Tele and sandwich a Rosewood strip between the two halves!
    George's has a maple strip between the two rosewood halves.
    Sent from my LG-H932 using Tapatalk
    Skydog1010 likes this.
  8. Peegoo
    Peegoo Tele-Holic
    That's why I mentioned having built hollow and chambered guitars in the past. I've already done it that way. Like you say, I'm just having fun with this one.
  9. Peegoo
    Peegoo Tele-Holic
    I have sheets of hardwood veneer and I considered doing ebony, but since I'm painting this, it won't show anyway.
  10. Blue Bill
    Blue Bill Poster Extraordinaire
    That's so radical! Make sure you take out enough material to make it light enough, after all this effort. You may want to weigh it and measure how much weight you have shed,before re-glueing it. Keep the pictures coming!
  11. bender66
    on my bike
    This is cool!
    All in!
  12. Macrogats
    Macrogats Friend of Leo's
    Auckland, New Zealand
    Wow, that is brilliant and so well executed.
  13. Peegoo
    Peegoo Tele-Holic
    Thanks! I had some time today to work on this.
    I used a 1" Forstner bit to remove wood in a honeycomb pattern. To make the holes match up when glued, I did a full-size drawing with the locations for the holes, and transferred the center points to each half.
    I decided on a honeycomb because it reduces the size of the cavities and the extra webbing between them increases the strength of the top and back. The thickness of the face, front and back, is 3/16". Pretty thin for soft pine; that's why I left a 3/4" band around the circumference because that's the area that takes the most abuse.
    This started out as a 3.5-lb body. I just got it out of the clamps and it weighs 2.5 lbs. It will probably lose perhaps another ounce once the glue completely cures. Dropping a full pound is pretty significant.
    I'll give it two days to cure and I'll get to sanding. I may do a larger roundover on the front and back...perhaps 1/2" or maybe 5/8". It will make for a really comfy player.
    You never ever have too many clamps :)
    Jim_in_PA, RiversQC and Macrogats like this.
  14. Dan German
    Dan German Poster Extraordinaire Silver Supporter
    Left of the Left Coast
    Very cool.
    If it were me, I would do a natural finish, and paint the seam to look like stitches.
  15. Macrogats
    That’s a great job on the reduction holes!
  16. DrASATele
    North of Boston
    Nice, you should have taken a tone test before and then do one after to see what you've added or subtracted from the sound. Cool project!
    RiversQC likes this.
