Yes, it's a given that with the development of the plane, people threw things against the wall to see what would stick. And it's a combination of all the ideas which ended up working that made the plane into the plane as we recognize today.
So let's name those things that made it as a standard feature in modern day planes and name the people who did it first and the planes that implemented those innovations.
Starting with the first wing design optimized for powered flight, which of course goes to...
This year sees the 120'Th anniversary of the Wright Brothers succeeding in the quest to getting an engine powered plane into the skies, so of course they have to be in this thread. So what gave Orville and Wilbur Wright the edge here?
Well, all their contemporaries like Samuel Langley used the designs penned up by Otto Lilienthal, who published a book about gliders and whose work was considered to be the bible of human flight. What the Wrights discovered was that Lilienthal's designs were flawed, his wings were fine for gliding, but they would never work with powered flight.
But the Wright's design wasn't perfect either, they would steer the plane by bending the wings by force, Wilbur recounting the dread he felt whenever the Flyer took off. If it were up to him, he would have burned the plane, it was that unsafe. Luckily, he never did, the groundbreaking aircraft is still around today.
Later, Glenn Curtis would take the Wright's design and started to add flaps and ailerons, creating the wings that aircraft still use today. But in a recent twist (Pun intended) those warping wings without the flaps that made the Wright flyer a health hazard, have people going "You know, that actually isn't such a bad idea." Because it allows for planes to fly more smoothly through turbulence.
Heck, a paraglider gets its manoeuvrability because it's essentially the Wright brother's original wing design.
The first plane which successfully flew with swept back wings.
Now, with this it's generally accepted that it was the Germans who in the second world war made leaps and bounds in the development of the jet fighter and the swept back wings to make the airframe cope with the increased speed. But they weren't the first.
This is the Dunne D8, which was a 1912 design of what is essentially a tail less, flying wing.
I guess, I don't need to say that this swept wing wasn't designed with supersonic speeds in mind. The angle is 32°, and it was all for the sake of stability. An earlier version named the D.5 achieved perfect aerodynamic stability in flight. The pilot actually took his hands off the controls and wrote a message on a note board in flight. A feat which was witnessed by Orville Wright himself.
The first functional helicopter.
Yeah, the philosophy is simple, and it makes so much sense; If you can use a propeller to generate thrust to lift a plane into the air by forward motion, you could do the same by directing it upwards. But as the footage shows here, it's not that straightforward as the aircraft has to deal with the torque of that rotor, and it takes a very fine balancing act to get it right.
But one man who DID get it right was Igor Sikorsky, who in 1939, came up with the winning formula, which all modern helicopters are still using today.
