Foot switch for old Traynor Guitar Mate Reverb
Discussion in 'Amp Central Station' started by ritten70, Oct 12, 2020.
  1. ritten70
    ritten70 TDPRI Member
    US
    Hi:
    I’d like to get a foot switch for the reverb and tremolo for my old Traynor. It has a separate 1/4” input for each effect on the back. Am I correct in thinking this would work?
    https://www.amazon.com/dp/B07KGFD6N7/?tag=tdpri-20
    Also, any special cables needed for the connection?
    Thanks!
    Paul
  2. galaxiex
    galaxiex Tele-Afflicted
    Edmonton, Alberta Canada
    That Boss switch "could work" but seems like a solution looking for a problem.
    No special cables needed for that amp foot switches.
    The switches themselves are simple on/off single pole latching push button switches.
    No power supply needed for simple foot switches.
    Even on old Fender 2 button Reverb and Vibrato foot switch will work with that amp,
    tho you would need connector adapters to got from the Fender RCA plug to the Traynor 1/4 inch jack.
  3. galaxiex
  4. ritten70
    US
    Thanks! One thing attractive about the boss is the ability to run longer cables - I do often run the amp behind the stage but the simple switch is attractive for sure.
  5. ritten70
    US
  6. ce24
    ce24 Poster Extraordinaire
    Idahoastan
    image.jpg I use this......its perfect. TRS to 2 mono 1/4” out from pedal. Works on my YRM-1 reverb master.
    beyer160 and tubegeek like this.
  7. beyer160
    beyer160 Friend of Leo's
    On Location
    I rewired the two TS jacks in mine to a single TRS jack so I could use a generic $20 two-button footswitch with a TRS cable. Just take the two "hot" wires to Tip and Ring, and wire the ground to Sleeve. If you can solder, you'll spend more time undoing the chassis than rewiring.
    $0.02.
    Tim S likes this.
