skipjackrc4
I've been wanting to make a fuzzy Explorer like the one ZZ Top used in the "Legs" video for years. I want to get some practice with spraying Brite Tone before finishing a Tele and Jaguar I have going on now, and what better way to practice spraying than on a guitar that will be covered in fur? ;-)
I'm making the body out of Poplar and the neck from flatsawn maple. I shrunk the giant upper wing on the body a bit so that the blank would fit through my 16" jointer. I think I like the shorter upper wing than the standard Gibson one, TBH. I glued up the poplar body with T88 epoxy, which I've never used. It seems to work well, but took a full week to cure and was much more of a hassle than Titebond or similar.
Body cut on the bandsaw:
I routed the body and pickup cavities as so:
I routed the control cavity and a 1/4" x 1/4" rabbet for a magnetic cavity cover. The rabbet was cut with a standard rabbetting bit. This pattern bit obviously is a bit dull, given the burning.
