Fixing a pickup
Discussion in 'Tele-Technical' started by VillainSean, Oct 28, 2020.
  1. VillainSean
    VillainSean Tele-Meister Gold Supporter
    Seattle, WA
    Hello Gurus,
    I have a tele neck pickup that just "stopped" working.
    what steps can I take to investigate what went wrong and how to fix it?
    TIA
  2. glenlivet
    glenlivet Tele-Afflicted
    Marco.......Polo......
    The first step, is to take off the control plate, and wiggle wires....it's quite possible that you just have a faulty connection to the switch....
    Do you have a multi-meter / Volt/ Ohm Meter and a soldering gun ?
    VillainSean likes this.
  3. Danb541
    Danb541 Tele-Afflicted
    Oregon
    make sure the two little copper wires are soldered to the baseplate (where the hot and ground wires come off the pickup. Ive had one break before, easy fix. Solder it back. You can also just solder both the connections anyways and see if that does it.
    Edit. I was assuming the pickup was not still in the guitar. Is it still in the guitar? If yes, then it could be a number of things. Most likely having to do with a bad solder connection.
  4. VillainSean
    Seattle, WA
    Thanks guys. I've taken them out of the original guitar and tried them in a different tele, to the same result. I can't see where any of the wires are broken. Maybe it's a just sort of "loose".
  5. glenlivet
    If the pickup isn't working (at all) in two different guitars....chances are you have a bad pickup.
    Use the Ohm meter to measure the resistance across the pickups two wires.
    (ie: measure the resistance of the coil)
    If the resistance is infinite...the coil is open
    (the copper wire has a break in it)
