Fix belly cut carving gone wrong
Discussion in 'Tele Home Depot' started by newuser1, Jan 17, 2021.
  1. SacDAve
    SacDAve Poster Extraordinaire
    Rocklin Ca.
    I'd just build a new body. Lesson learned one time mistake
    newuser1 and stratclub like this.
  2. Collin D Plonker
    Collin D Plonker Tele-Afflicted
    Delaware
    I mix fine sawdust with Titebond to make wood filler
    newuser1 and Skydog1010 like this.
  3. Ronkirn
    Ronkirn Doctor of Teleocity
    Jacksonville, FL
    that upper rout is supposed to be 1 ⅛ deep. not 1 3/8ths as are the others... ( I've seen others do the same thing..) I'd just pour a layer of epoxy in it... and let it ride...
    r
    newuser1 likes this.
  4. Telenator
    Vermont
    epoxy. Just fill the corner with small amount of epoxy and you're done. And then accept that this one won't have a natural finish. No big deal. Don't try putting any wood in there without first using epoxy. You need to be positive that all air voids are filled or you're going to have more problems trying to blend the curve from the outside. No big deal.
  5. Jim_in_PA
    Jim_in_PA Friend of Leo's Silver Supporter
    SE PA near New Hope PA
    I'd fix that from the inside with a little resin and tape to hold it in place, allowing some to go through the boo-boo and then (carefully) sand it smooth. Using a darker finish treatment, particularly on the back of the guitar will totally hide this, not that most folks would ever notice. Only you will know it's there, honestly.
    newuser1 and Telenator like this.
  6. newuser1
    newuser1 Tele-Holic
    Toronto
    I glued in this piece of cherry, because I was cutting a cherry Bass VI and that was the easiest option. Now I have a lovely cherry spec at the back of my poplar body :)
    Even though this will be a solid color I wouldn't have a problem doing a transparent finish.
  7. Jim_in_PA
    That actually looks like a "natural feature". Good fix!
