Fishman Powerbridge wiring
Discussion in 'Just Pickups' started by capohk, Jan 28, 2020.
  1. capohk
    capohk TDPRI Member
    Hong Kong
    A quick question to help with my sanity or otherwise...
    I've wired up a Fishman TOM Powerbridge in my 335. I followed the wiring diagram for passive direct connection to the stereo jack and checked to make sure it worked before reinstalling all of the pots etc, which was lucky because it didn't. Just a constant ground hum.
    I unsoldered the magnetic pickup circuit so that it was just the Powerbridge - same problem.
    So I checked for continuity with all of the ground points. Turns out that the hot lead (centre) is continuous with all ground points and the shield (ground) is not. Like the pickup is wired backwards somehow. The shield has no continuity with the bridge case.
    Any ideas welcome. I'm thinking it can't do any harm to try wiring it backwards at the jack and seeing what happens.
    Cheers
  2. sjtalon
    sjtalon Doctor of Teleocity Ad Free Member
    Upper Peninsula of Michigan
    I would try reversing, they could have soldered the wire colors wrong, it happens on pickups now and then.
    I've had two so far in my life that they wired (leads) backwards on.
  3. capohk
    capohk TDPRI Member
    Hong Kong
    No colours, just one single lead with hot centre and shield. Shield is not continuous with the bridge case, while the hot is, so must be a dead short within the unit. Back to the supplier I guess.
