First Two MJT builds... (pictures)
Discussion in 'Other T-Types and Partscasters' started by r_o_b_s_o_n, May 26, 2019.
  1. r_o_b_s_o_n
    r_o_b_s_o_n TDPRI Member
    Victoria BC, Canada
    So... it was an interesting week... I placed an order for my first MJT project way back in November - a Blackguard Tele clone. I got a bit impatient waiting for updates and awaiting for it finally ship, so... I ended up buying an MJT Strat body from ebay... I received the Strat 6 days after buying it. As it happens, I finally got notification that my Tele was shipping. I received the Tele exactly one week after the Strat... So, now I have two concurrent builds!
    Turns out that in the box was the body, neck, bridge and pickguard. I was honestly less than impressed with either the pickguard or the bridge. For one, they shipped me a left handed bridge, and while it may not be a huge deal, the bridge is a top loader type.
    The pickguard is a single play black plastic - not bakelite as I hoped (I had asked if it was bakelite or not when I ordered and never got a straight answer).
    So, those are two parts that will be going in the spares bin. I also found that I did not get string ferules nor a jack cup... so those are two more items I will have to add to the shopping list.
    Anyway, all in all I am pretty pleased with the body and neck (I still think their approach to relic'ing is a bit contrived and has a tendency to exhibit un-natural repetition in their dents and finish wear).
    I'm at a bit of a stand still now while I await additional parts, but as with the strat body, I managed to get the shielding done and small wire jumpers soldered in to connect the different cavities...
    I took a some photos as I unboxed the body and neck (with the help of my little kitty - Nootka), and tried to detail some of the process of masking the body, sanding the body cavities, tracing patterns for cutting the copper tape, and then the finished grounding. I think it turned out even better than on my strat body. Finally I dry fit everything and mocked it up - SWEET!!
    Anyway, enjoy a few more photos! I will post more once I get the rest of the hardware.
    Cheers,
    Geoff
    The box as it arrived...
    Nootka doing her part to help with the unboxing.
    The well protected contents of the big box.
    Everything opened up.
    First step was to mask off the body cavities to protect the finish when sanding.
    Sanding the body cavities to knock down the rough overspray in the cavities to prep for shielding.
    I used parchment paper to trace the shape of the cavities which allowed me to cut the copper tape to the correct shape.
    Finished shielding job. I wish I had taken more pictures of the process.
  2. Toadtele
    Toadtele Tele-Holic
    Idaho just the tip
    Nice. Enjoy!
  3. r_o_b_s_o_n
    Victoria BC, Canada
    more pictures
    I came across this little tin lunchbox some time ago and thought it would make a great box for electronic components and tools.
    Inside the Fender box...
    Seymour Duncan Antiquities will be installed in both guitars. I love their presentation. Can't wait to hear them!
    The flat pole bridge pickup - beautiful
    Body and hardware mocked up without neck
    Mocked up with the neck dry-fit in place
    Mocked up with the neck dry-fit in place, hanging out with it's Strat sibling.
    Body & Neck resting in its lush new home.
    baiff, dickjonesify and stefanhotrod like this.
  4. rangercaster
    portland, or
    The cat likes it ... Therefore, it should be fine...
  5. r_o_b_s_o_n
    Victoria BC, Canada
    and a few shots of the Strat body...
    Copper shielding in place.
    I ended up having to use my dremel to re-work the inside of the output jack cavity, as I checked the continuity between the tip of a cable plugged into the jack and the copper shielding in the main cavity and my multimeter indicated the the tip was shorting against the shielding.
    mmmmm, Sonic Blue
    Planning on building this as a '62
    The tweed case is for the Tele, the Strat will get a Brown Tolex case
  6. Misty Mountain
    Misty Mountain Tele-Meister
    Seattle
    Very nice!
  7. Ian T
    Ian T Tele-Holic
    Tampa Bay
    It all started for me in a similar way. I had watched the Ebay page for a couple of years before I pulled the trigger on a custom build. Then, before it was finished I impulse bought one off their page and that ended up being my first. A few years later I have, let me count, a strat, 4 thinlines, and 2 teles. I can't stop myself. That page is the death of me. Sometimes I get bored, add a few to the watch list and it just keeps going. Tomorrow my Rutters hardware arrives for a blackguard build. As if I need another Tele. Even worse, I almost sniped another body this week. It's a problem. Yet all I can say is Yay! Tomorrow I get to screw together a blackguard and I can't wait to try these pickups!
    I love every one of them to death and get immense satisfaction from them. Plus, they are utility tools, that if something happens to them it's no biggie as it is with something collectible. I use a couple of them as gigging guitars in a wedding band and leave them in our band trailer between gigs, harsh Florida heat, with no worries. If the necks don't have the meddle, they can be replaced.
    Every one of them has had a very tight neck pocket and the bridge mounting holes perfectly centered without any adjustments needed whatsoever to get a perfect string line. Plus the Jennys have top notch customer service. If you didn't want the SRV backwards trem, just send it back and I'm sure they'll make it right.
    Congrats on your new guitars, I'm sure you'll love them.
  8. r_o_b_s_o_n
    Victoria BC, Canada
    Here are pictures of the finished Tele.
    • MJT Swamp Ash VTT body
    • Musikraft Blackguard Neck (Soft V & 7.5"-9.5" compound radius)
    • Seymour Duncan Antiquity Pickups
    • Emerson/CTS Pots
    • Wired w/ blackguard "Dark Circuit" & 2 Emerson Paper in Oil caps
    • All slotted screws
    • Lacquered Bakelite pickguard
    • fully shielded with copper tape
    • Fender 3 saddle bridge
    DSC_1616_sq.jpg DSC_1618_sq.jpg DSC_1628_sq.jpg DSC_1637_sq.jpg DSC_1662_sq.jpg DSC_1663_sq.jpg DSC_1675_sq.jpg DSC_1690_sq.jpg DSC_1703_sq.jpg
    SuprHtr, Nubs, baiff and 3 others like this.
  9. Festus_Hagen
    Festus_Hagen Tele-Holic
    Jeff City, Mo.
    Very nice !
    r_o_b_s_o_n likes this.
  10. DrASATele
    North of Boston
    Wow, that's sweet.
  11. r_o_b_s_o_n
    Victoria BC, Canada
    Thank you both!!! Definitely a learning process!
  12. chris m.
    Santa Barbara, California
    That's some of the cleanest copper tape mounting I've ever seen. I'm not nearly that patient. I just slap it in there until it's all covered up....
  13. Telemaestro
    Telemaestro Tele-Meister
    Hartville, Ohio
    Classic. Love it. Also, lovely photography.
  14. rze99
    rze99 Poster Extraordinaire
    South London UK
    Nice build with top components, very nicely put together and photographed. Well done!
  15. TeleTown
    TeleTown Friend of Leo's
    Twangers Medows USA
    Nice looking T-style. Hope you never plan on selling it with that fake decal on the head stock.
    Mike Simpson likes this.
  16. r_o_b_s_o_n
    Victoria BC, Canada
    Nope... never
  17. baiff
    baiff Tele-Holic
    FLOOR-AH-DUH
    Don't post this on TGP....they will call the cops and throw you in jail for this offense. But seriously, great looking guitar at a fraction of what a boutique tele would cost you.
  18. Fendereedo
    Fendereedo Friend of Leo's
    Really nicely done. Enjoy.
  19. r_o_b_s_o_n
    Victoria BC, Canada
    Finished the Strat build, and got some pics to share...
    • MJT Alder VTS body
    • Musikraft Neck - V to C profile & 9.5"-12" compound radius Indian Rosewood slab board
    • Emerson/CTS Pots
    • Wired w/ original Strat wiring (No tone in Bridge position) & Emerson Paper in Oil cap
    • Fender AVRI bridge
    DSC_3357_sq.jpg DSC_3369_sq.jpg DSC_3305_sq.jpg DSC_3378_sq.jpg DSC_3392_sq.jpg DSC_3418_sq.jpg DSC_3294_sq.jpg DSC_3345_sq.jpg DSC_3370-2_sq.jpg
    *yes - I applied a Fender decal. I have no intention of selling either guitar, ever.
    hrstrat57, baiff and Chunkocaster like this.
  20. Chunkocaster
    In space with Ziggy
    Beautiful looking guitars and great pics.
    No need to justify the decals to me, I don't own shares in the company and I prefer a authentic looking replica without being bled for the privilege too.
    Plus it's way more fun to put your own together.:)
    r_o_b_s_o_n and baiff like this.
