First-timer 5E3 kit build
Discussion in 'Shock Brother's DIY Amps' started by DanTel, Jan 13, 2018.
Tags:
  1. DanTel
    DanTel TDPRI Member
    Arlington Heights, Illinois
    Hello all! I'm taking the plunge and building my first amp from a 5E3 kit bought from Dave at Boot Hill. I decided it's time to build the real thing after discovering a 5E3 emulation pedal a couple years ago, that has now become a part of my rig that's almost always "on" whenever I'm playing... I know, I know, not the same thing at all, that's why I'm really looking forward to playing through this amp when it's done. ;-)
    I want to start with a thank you to all who have posted their build stories and photos, as I've read many and learned a lot, and especially to RobRob's awesome site!
    I've got some photos of my board before soldering, and if anyone would be so kind as to take a look and provide any feedback or things I should address before I solder, I would certainly appreciate your thoughts.
    There's a top view, and a front and back angle, but if you need to see anything up close, let me know. Thanks in advance, this is going to be fun!
    -Dan
  2. theprofessor
    theprofessor Friend of Leo's
    Chattanooga, TN
    Man, those Orange Drop coupling caps make life difficult for the other pieces on the board! I'm hardly a pro, but the only thing I see is that you might try to move that last cathode bypass cap away from the first filter cap.
    Also, does the Boothill kit come with the lower value on the first two coupling caps (.022uF) instead of the schematic .1uF? Those first three from the right are the same size.
  3. SacDAve
    SacDAve Poster Extraordinaire
    Rocklin Ca.
    Advantage to making your own boards
    Nickadermis likes this.
  4. D'tar
    D'tar Friend of Leo's
    WNY
    Builders choice.....a conversation with dave and he will set you up with what you want
    SacDAve likes this.
  5. DanTel
    DanTel TDPRI Member
    These are all .022uF. I didn't specify, but I did ask Dave about it after I opened the kit. He said he does all his kits this way, and his builds for customers, because the amp is too boomy and bass heavy with .1uF caps there.
    Thanks, Professor. They're not quite so close in 3 dimensions as they appear in two, but I will try to get some more separation. And yes, the Orange Drops certainly do hog the real-estate!
  6. DanTel
    DanTel TDPRI Member
    I see what you mean. Maybe after another build or two, I'll give that a shot, assuming I don't screw this one up!
  7. hackworth1
    hackworth1 Friend of Leo's Vendor Member
    Volusia County, Florida
    Looks good.
