first time tung oil user
Discussion in 'Finely Finished' started by fatcat, Feb 22, 2012.
  1. fatcat
    fatcat Friend of Leo's
    Very Deep South
    FUN! I LIKE IT, IT'S PUURRDY. :D Using it on a pine 1x12 cabinet with dovetail joints. Got it cheap, but it looks good.
    I have to say though, I left the cabinet in my bedroom, unfinished, for a while waiting for some warm days. Result; the wood completly drank up the first coat.
    Question, probably a dumb one. How many coats should I put on the inside of the cabinet? I had planned on putting one, or two, just to seal the surface.
  2. skimballc
    skimballc TDPRI Member
    San Francisco
    You could use at least a couple more. I stop at no fewer than 5. That pine is some thirsty stuff, now that it's sealed you'll be to build the finish up.
  3. fatcat
    Very Deep South
    5 coats on the inside of the cabinet?
    I was going to use at least that many or more on the outside. The guy that built it had one that was finished with 10 coats, buffed with steel wool between each coat; That thing was beautiful.
  4. skimballc
    San Francisco
    Since you're the one looking at the inside of it, stop when you are happy with it. Amount of coats also varies by how thick you lay it on
  5. GroovePuppy
    GroovePuppy TDPRI Member
    Windsor, CA
    +1 on this. I think a couple of coats is enough to seal it against damage but more with polishing will gloss up the finish. I believe I stopped after 3 or 4 on the project below but I wanted a flattish finish.
