Bass Butcher
The shim should be at one end or the other, not with a gap either side. You just run your screws through it with paper or card stock shims or line it up and poke a hole through prior to re-installing the neck. A full shim would be better, a sturdier neck/body joint and better sustain transference between the neck and body but there is more to that than just getting full coverage, you might have to sand your shim to the desired angle, which involves some trial and error, remounting the neck a few times at least until you get it where you want it and starting all over if you go too far. The partial shim compromise is to test seat it until you get your shim thickness correct, take it apart again and use wood filler to fill the void between the shim and lumber.
I have seen wood filler used even on factory neck joints, it usually turns back into a powder after a decade or two though.
If you are close the pressure from seating the neck with the screws will level it out and squeeze out any excess.
As with any screw(s) you remove from a guitar you should also paint a bit of the threads with white or carpenter's glue before re-installing the screw(s). That helps avoid over tightening/stripping threads in the wood, fills any voids cause by shrinkage, etc. and locks the screw in place. Neck screws are the screws that benefit from that the most. That technique will also repair blown out threads, although it is better to fill badly blown out screw holes with wood and glue and re-
drill the hole once the glue has time to set.
