Hallski
New the world of bolt ons, mostly everything I've played has been set neck, so thats what I'm used to working on. But, I've been fighting a few things on my Road Worn for a while, and I think have fixed one of them by shimming the neck. The bridge saddles were WAY up, the screws were almost bottomed out in the barrel (like, screwed all the way down) and my intonation screws were sticking through the strings. I knew something was up.
Been reading through TDPRI about shimming, and I found that I should shim the headstock side of the neck pocket a bit to help with the angle, and WOW what a difference it's made. I was able to lower my saddles MUCH lower and get my action to more playable spot for my liking. So I'm glad for that.
My question isn't so much, do you like neck shims. Rather, how did I do? Is everything looking right? Using what I saw online (famous last words!), and what I had around, I cut a shim out of the top of a cereal box, and cut it so it would avoid the mounting holes. There is a slight gap now on the top of the pocket, of course. Screws are as tight as I can get them, neck isn't moving even if pulled on. Heel seems to be seated well in the pocket at the bridge side (see pictures)
But is that OK? Or should I grab one of those StewMac tapered shims? If so, what angle? Likely the 5 degree from what I've read.
Just curious of your thoughts, I've never done this before, and while it seems to have helped my issues, I don't want to create any further issues down the road.
(SIDE NOTE: When I pulled the neck, the finish and clear coat was REALLY stuck on the neck at the pocket. Seems to have cracked a little bit at the neck, I'm sure its only cosmetic, and it will live under the pickguard)
