MatsEriksson
Here I go again, but many has said this before:
1. A capo on first fret, and press with one finger on last fret of all the strings. On 12th fret it should show a slight gap.
2. Adjust truss rod. Takes a while, wait 15 minutes for it to settle after each turn. Of course, brand new strings, up to tune.
3. Then take off the capo and do the nut test. Press finger at 3rd fret, and see to that there's a hairs gap between all strings and the first fret. So tiny a gap that only @Telenator for sure has the right name for it.
4. All the rest, now you can adjust string height with the bridge saddles up and down. At your own peril, and to your own taste. Mind you that you may like to bend the outer strings so they don't choke fret out when they reach middle of the fret board.
5. Now, pickup height. Make sure the pickups distance follow whatever changes you do to string height. Avoid magnetic string pull (MSP) to the strings. Which can be a liability. Or not.
6. Intonate.
7. Play.
(10). Optional. If your guitar has been in case for long. You may benefit, and feel and hear difference, if the neck is pulled back into the neck pocket towards the body a tiny fraction of an inch. When tuned up, loosen the screws one by one at the back, with a max quarter turn each at the back. Until you hear a slight crackling sound. Fasten them again. I e the strings pull pulls the neck back and further into the neck pocket now being flush with the body end of the neck pocket. Direct coupling. You may have to redo intonation after that of course. Sometimes it doesn't do anything (mostly) and sometimes the difference is like night and day. The times I've encountered, is that more often than not it didn't do anything, not even subtle changes. But when it did matter, it was a huge difference and always towards the positive side. The direct coupling added mass to the overall construction, so to speak. So verdict: either it does absolutely nothing, or do huge amounts of things, especially in the sustaining of most notes across all strings, and even got rid of some slight dead spots here and there. There's no "in between".
6. Intonate.
7. Play.
