First Telecaster build
Discussion in 'Tele Home Depot' started by SammyC, Jun 9, 2020.
  1. SammyC
    SammyC Tele-Meister
    So time to try building a telecaster! Two previous guitars have both been Gibson style ones so time to do something different.
    Bought a slab of supposedly swamp ash:
    Order said 1.8kg, but my scales show closer to 3.3kg lol.
    I guess for £68 I shouldn't be too surprised :)
    First thing is to get some drawings downloaded and sketched out on the blank.
    Plustop, zippofan and theprofessor like this.
  2. Ronkirn
    Ronkirn Doctor of Teleocity
    Jacksonville, FL
    For your first, do not make the number one goof most guys fall into.. trying to make the first their dream guitar.. it just doesn't work.. as you get into the project you begin absorbing things you weren't aware of.. that causes you to rethink what would be the dream guitar...and.. that bubble bursts..
    If you keep it traditional, you learn much and by around your third, (there will be more). you will have a much better idea about what would be your number 1
    I have some "stuff" I wrote a few years back available free on my website... help yourself and I hope it helps ya.
    https://www.ronkirn.com/books-1
    Ron Kirn
    esetter, Plustop, Mr_Q and 8 others like this.
  3. KW1977
    KW1977 Tele-Meister
    Virginia
    This is terrific advice. My "dream guitar" has been so mercurial over the years I'm glad that I didn't immediately pull the trigger on it. Learn the standards/foundations of things cold and branch out from there. You'll be doing so from a much stronger place.
  4. Ronkirn
    Jacksonville, FL
    there's other considerations... some are on tight pursestrings.. also known as the Wife... and before starting number two, it becomes necessary to divest of number one.. If you've made a purple BassBoat glitter with 4 pups, coil splitting, phase reversal, and Posi-traction... you're gonna have a hard time moving that puppy.. but if it was a traditional black guard. *poof*. it's outta there like the Road Runner .. beep beeeeep . .
    r
  5. SammyC
    SammyC Tele-Meister
    Great advice, thank you. I think this could be considered my third guitar:
    First I built about 30 years ago as a teenager, SG copy, original SD Trembuckers, Floyd Rose floating bridge, and a 7-9 radius neck. I never could work out why the string height had to be so high and it is only now I see how badly teenage me selected parts! Still, that was pre-internet so very little information to go on.
    Second I've just about completed, its for my son, although he's only eight and I think the neck may be too chunky for his small hands. It is the one I've tried to make interesting probably at the cost of over complexity!
    This one, number three, I'm keeping simple in terms of choices. Top-loader hardtail bridge, twin P90s, standard front control panel, probably no pick guard, off the shelf neck from reputable source. Cut, route, sand and stain body, seal with a hardwax.
    Does that sound too ambitious or ok?
    fenderchamp likes this.
  6. Old Deaf Roadie
    Old Deaf Roadie Friend of Leo's Silver Supporter
    Oregon
    All my builds have started with "I'll sell it", and end with an emotional attachment and "It's not going anywhere, and I may need a new pedal and definitely a case..."
    crazydave911 and nicknklv like this.
  7. Ronkirn
    Jacksonville, FL
    yep. I wish I had every one of 'em... memories..
    r
    crazydave911 and Old Deaf Roadie like this.
  8. Jim_in_PA
    Jim_in_PA Friend of Leo's Silver Supporter
    SE PA near New Hope PA
    Even as a newbie, I agree with this. My first was pretty much straight Tele-style with just a minor deviation in the headstock shape. I learned a lot from that build for sure. I cringe a little when I look at it closely because of the flaws. But it sounds really good so I was tickled nonetheless. It helped confirm that A) I wanted to continue doing this and B) that the Tele-geometry could go far for me as I got more creative visually.
    crazydave911 likes this.
  9. SammyC
    SammyC Tele-Meister
    Thanks everyone, great advice as always :D
    So, I've got the blank and I know what shape body I'm building (Telecaster), I think the next most important part after the neck is probably the bridge?
    I'm thinking of top loader hard tail, relatively modern, and fits a P90. Any suggestions?
    trev333 likes this.
  10. guitarbuilder
    If your dream guitar is a basic tele...then go ahead and make your dream guitar....lol.
    A top loader/ hard tail bridge does not hold a pickup. The pickup sits in front of the bridge. The only tele bridges that fit real p90's that I've seen were kind of custom machined.
    https://reverb.com/item/2168884-gpg...l-bridge-plate-for-fender-tele-telecaster-p90
  11. trev333
    Coolum Beach,Australia
    my first two builds were hard tail 2xP90 Teles.. still getting played, too..
    Warman UK P90's are what I use in a lot of builds... won't break the bank either,,:)
  12. Ronkirn
    Jacksonville, FL
    a Soap bar P90, takes a rout that can be quite precise, so that a surround, be it as integral to the bridge or a single piece are not really required...
    here's an example, though it' DSC_7896.jpeg s at the neck position
    r
    Plustop and crazydave911 like this.
  13. SammyC
    SammyC Tele-Meister
    So any hard tail bridge, that doesn't include a hole for a specific pickup, will work?
  14. SammyC
    SammyC Tele-Meister
    @trev333 why did you rotate the bridge P90?
  15. RickyRicardo
    RickyRicardo Friend of Leo's
    Calgary, Alberta
    The one that I built has 2 P90's and a Wilkinson string through half bridge. No pickguard. Any top load F style bridge will work.
  16. Dana Rudd
    Dana Rudd Tele-Holic
    Greybull, WY
    Will be watching for progress on this build. Thanks for sharing.
  17. Jim_in_PA
    Some bridges vary with width/string spacing and height. There are also intonation considerations if string-through comes into play. I had a problem with a recent build around that where the hardtail I bought was a quarter inch off for intonation as compared to a standard tele bridge when string through holes (which were already drilled by my CNC machine) were taken into consideration. I had to abandon that bridge for the project and get a different one.
  18. Chuckboy
    Chuckboy Tele-Meister
    Jeddo
    Ron,
    Can you say where one can get the templates mentioned in the Tele Shaping Book?
  19. Ronkirn
    Jacksonville, FL
    nopt really. I discontinued making them over 10 years ago..
    r
  20. SammyC
    SammyC Tele-Meister
