First real build....
Discussion in 'Tele Home Depot' started by mo62987, Jun 21, 2019.
  1. mo62987
    mo62987 Tele-Meister
    B'ham, AL
    Ok, let's turn some stuff into a guitar!
    Have done a couple parts builds so far, and a 'practice' build from scratch using mostly stuff i already had. Ready for the real thing now. Will probably take quite a while since I'm kinda short on 'free-time', but here we go!
    Body glue up. Nice 8/4 ash i picked up a while back. Had an edge jointed at the lumber yard, and I cut the two pieces to length a few weeks ago. Think it moved on me slightly since it's been sitting, had to try to dress up the edges again before glue up. Not sure i did a fantastic job, but think it'll do.
    Maple for the neck. Found a length with a bit of figure to it
    Got to use my new-to-me planer and hack it down to 3/4", then rough cut with the jigsaw
    Sanded to the line, then over to the router table. Still had an area tearout at the heel - you can see the repair in the bottom right of the next photo
    Using the jig to route the truss rod slot
    StewMac Hot rod with the Fender style adjustment. Free handed the wider area to slip the adjustment nut through
    That'll do
    Fretboard locators before i cut them down
    Then hacked the LMII pre-slotted fretboard down to size before glue up
    That's how she sits for now waiting on my clamps to free up from the body.
  2. mo62987
    B'ham, AL
    After a very busy month or so of being on the road for work and sleeping in hotel rooms more than my own bed, I got to steal a few minutes here and there to work on this.
    Finished the fretboard glue up and trimmed it down to size. Then moved over to routing the body shape. Lack of a band saw meant hacking away the majority of the waste with carefully placed miter saw cuts and drilling first and finishing with a hand saw. Then VERY slowly taking many passes with the router to avoid tear out. Didn't get too far with that part just yet.
    Only issue i ran into was a small bit of chip out near a fret slot. Does this look fixable with the sawdust and super glue trick?
    Fergyuk likes this.
  3. mo62987
    B'ham, AL
    Oh! and an inspiration pic for this build...
    Steveinthesticks and Fergyuk like this.
  4. Ronkirn
    Jacksonville, FL
    I gotta tell ya.... I'm not a big fan of Bigsbys... or relics, but damn... that's one fine lookin' lady there... not to shabby for a first real build any build for that matter..... I hope you're there to see your grandson show your Great grandson those first few chords... congrats... rock on..
    rk
  5. mo62987
    B'ham, AL
    @Ronkirn I'm not a huge fan of pre-relic'd guitars either so I'll go for a fairly thin nitro coat and (hopefully) let the years do the work for me.
    And i think i'll go for a top loader first... Bigsby to follow later
  6. Ronkirn
    Jacksonville, FL
    did you access my booklets of instructions.. they may help, though what I see of your shop you're probably well familiar with the basics and splinters..
    r
  7. mo62987
    B'ham, AL
    @Ronkirn Yes i have perused your booklets, and read through some of your detailed build threads (as well as many others'). Thank you for sharing your wealth of knowledge so freely!
  8. mo62987
    B'ham, AL
    Slow goings but body is shaped finally
  9. mo62987
    B'ham, AL
    Neck pocket done
    Fergyuk and crazydave911 like this.
  10. mo62987
    B'ham, AL
    Good snug fit
    Fergyuk, crazydave911 and RiversQC like this.
  11. mo62987
    B'ham, AL
    Today we gots dots
    And dots
  12. mo62987
    B'ham, AL
    And an ok repair for that fret board chipout
  13. mo62987
    B'ham, AL
    The onto headstock thinning and transition. Still need a little work in this area
    Fergyuk, builtbyseb and Jim_in_PA like this.
  14. mo62987
    B'ham, AL
    Bridge aligned
  15. mo62987
    B'ham, AL
    Made a template and routed the recess for the rear control plate
    upload_2019-9-1_17-5-54.jpeg upload_2019-9-1_17-6-23.jpeg upload_2019-9-1_17-6-56.jpeg
    Not quite as clean as I would have wanted. But not too bad either.
    Fergyuk likes this.
  16. mo62987
    B'ham, AL
    Let’s do this...
    Primary facet done
    Almost there. Just needs some dressing up. But I was pretty tired of rasping, filing, sanding at this point
  17. mo62987
    B'ham, AL
    Moved on to fretting (at some point during all this I drilled for the jack too)
    This was my first time fretting. It seemed much more intimidating than it really is. Only one fret gave me trouble where I had some CA glue build up in the slot from that repair earlier. Still might have to pull it and try again.
    Ends all dressed up.
    Fergyuk likes this.
  18. Luthi3rz
    Luthi3rz Tele-Meister
    AZ
    Nice
    What size bit you use for the control cavity?
  19. jimilee
    jimilee Tele-Afflicted Silver Supporter
    Chattanooga
    Very cool. Looking good.
  20. mo62987
    B'ham, AL
    Thanks guys!
    If you mean the rear route, I just used a 1/2” router bit. For the deep route and the rebate.
