First Build
Discussion in 'Tele Home Depot' started by aarongreen123, Jun 20, 2014.
  1. aarongreen123
    aarongreen123 Tele-Meister
    Thanks a lot for the info so far guys. Went out and bought some wood today, step one is out of the way:)
  2. mandocaster
    mandocaster Tele-Meister Gold Supporter
    Houston, TX
    It looks great so far! Hooray for step one.
  3. aarongreen123
    picking things back up, summer got in the way. working on thick-nessing the body blank and collecting some tools. just got a 12" craftsman bandsaw for 60 bucks, that should go to good use.
  4. aarongreen123
    that piece of maple got too thin to quick, so its going to become the fretboard. working on a piece of walnut for the neck.
  5. fretman_2
    fretman_2 Friend of Leo's
    Mobile, AL
    Good luck...you'll do just fine.
  6. Dr Coolhand
    Dr Coolhand TDPRI Member
    Rio Grande Valley (temp)
    Make templates. I learned the hard way how easy they make routing and accuracy.
    I just finished my first build a couple days ago. Take it easy and you'll do great!
  7. aarongreen123
    I have master templates, need to make some working templates.
    5/8 is too thin for a neck blank right? That piece of maple is 5/8, can I compensate with the fingerboard?
  8. Dr Coolhand
    I might be wrong but I'm pretty sure the neck black should be at least 1"thick.
    Haven't made one yet but 5/8"seems thin.
  9. lbridenstine
    lbridenstine Friend of Leo's
    Kalamazoo, MI
    I think 5/8" neck + a 1/4" fretboard would be fine. Just adjust your neck pocket depth if needed. If you're doing a Fender style headstock, I don't know about the thickness needed for that.
  10. aarongreen123
    How does it relate to the depth/space for truss rod?
  11. OpenG Capo4
    OpenG Capo4 Friend of Leo's
    Athens, GA
    The truss rods I use (the "blue" ones you see on ebay) are routed 3/8 deep. You'd have 1/4" of material between the back of the neck and the truss rod. And the "standard" profile is .83 or so at its thinnest. You'd have about that much, but it wouldn't taper to the full thickness at the other end. It'd be like a skinny shredder neck.
    Standard headstock thickness is about 9/16 so you'd probably be ok there.
    An option you might consider is adding some material (like veneers) at the ends of your blank to add thickness where you need it.
