nickhofen
Scrapers,planes, orbital sander and a lamp to help me see the imperfections.
Coming along nicely.
Thanks John, much appreciated!Nice work.
If you start making your own templates from mdf and practice on cheap wood on the beginning,one day you will wood work better than that!Wow, that is beautiful.
I wish I could wood work like you guys!
Nice looking one Nick. How far does the plastic extend down? Does it interfere with using the whole length of the bit?Testing my 3d printed dust show.
I will try to cut the neck on the cnc , although for me it is tricky to machine an angled guitar neck on a cnc ,even I don't know if i will make it to the end, I am sure I am going to learn a lot. I follow Austin Shaner on YouTube and Facebook, the guy seems to know what he is doing with fusion360 and cncing.Well done. Are you going o be cutting the neck on the CNC? Are you going to make the tenon a hair smaller so it fits in?
That's a good input to make the tenon a hair smaller to fit in, I have to say there are so many things in my head right now about the procedure that I haven't think of that at the time.
I wonder why this thread is not a sticky one yet.On my LP necks I use the truss rod slot as my centerline. I cut the tenon and neck up to the peghead transition. The tenon top has the angle. I do the peghead flat on the table as a separate file. I'd make your tenon a hair bigger and hand fit it like they do at Gibson unless your router's accuracy is that good....
See post 229 and on:
Let's make a neck ( volume 2)
A single edge razor blade acting as a scraper takes care of the glue drips. The side dot holes now get drilled and the dot rods get glued in with ducowww.tdpri.com
Coming along nicely, Nick!I wonder why this thread is not a sticky one yet.
Thanks Rick.Coming along nicely, Nick!
