first build... the "Sterkaster"...
Discussion in 'Tele Home Depot' started by sterkyyy, Oct 10, 2013.
  1. bob1234
    bob1234 Tele-Afflicted
    Michigan
    Seriously, do yourself a huge favor. When you rough carve the neck, let it sit for a few weeks. Let it move out and then finish it off.
  2. sterkyyy
    sterkyyy TDPRI Member
    northern colorado
    build update: I cut the control cavity plate from two boards of ziricote I had leftover from a previous build.
    I cut out the bird on the top wood, then glued it on the walnut body. I luckily had enough clamps to cover a good deal of the border.
    Here's a close up of the bird cutout. I just recently got a scroll saw, and it works amazingly in cutting stuff like this out. Very happy. There's some more fine sanding left to do.
    Technically the notch on the back by the control cavity was a router slip, but it also works pretty well for a notch to get the control plate out, too :)
  3. sterkyyy
    northern colorado
    Thanks, I'll let it sit for a while. Luckily for me, the wood was an inch thick, so I was able to machine out the warp to 3/4 inches with a router sled. Now it's pretty darn straight.
  4. Glen Smith
    Glen Smith RIP
    The bird looks very good.
  5. xaxxat
    xaxxat TDPRI Member
    Where did you find this jig?
  6. sterkyyy
    northern colorado
    http://sixgunguitars.com/fret_slotting_jig.html
    I got a pre-slotted maple board from stewmac for 13$. tape that to your fretboard you want to cut, then the use the razor blade in the jig as an index pin for the top board to cut. The site explains it better
  7. TeleSky
    TeleSky Tele-Holic
    Highland, Utah
    +1
    The fret slotting jig is on my to do list as well, now that you reminded of me, I think its time to move it up the priority list.
  8. lbridenstine
    lbridenstine Friend of Leo's
    Kalamazoo, MI
    The bird looks great!
  9. sterkyyy
    northern colorado
    Thanks yall for all the compliments on the bird! I like it as well. Well I cut the pickguard and the hole for the Charlie Christian and installed in the pickguard, and I love the way it turned out. But I need an opinion from the TDPRI community. I'm trying to figure out what layout for the knobs and switch. So choose either...
    A (Straight):
    or...
    B (Angled):
  10. Picton
    Picton Friend of Leo's
    Reading, Massachusetts
    Straight.
  11. lbridenstine
    Kalamazoo, MI
    I think A looks good.
  12. TeleSky
    TeleSky Tele-Holic
    Highland, Utah
    A looks better to my eyes.
  13. BR06623
    BR06623 Tele-Meister
    Dallas, Texas
    I like "A" too. This whole build is looking great!
  14. Ronsonic
    Ronsonic Tele-Afflicted
    Sunny Tampa, Florida
    Can I suggest "C"? Put the switch on the upper bout and relocate the knobs. That area is going to get real busy when you play and having the switch right under the bar ....
    Otherwise, A looks righter.
  15. sterkyyy
    northern colorado
    After I put this together I was actually thinking of doing that... let me see what I can do.
  16. sterkyyy
    northern colorado
    got around to working on the neck. I got the fretboard glued on over the neck wood and truss rod. I got the inlays drilled in and glued in. happy with the fretboard. [​IMG]
    But with this came some problems. After gluing on the fretboard I realized I didn't caulk the truss rod in the neck wood. It vibrates a little. I can get over that. But when I was contouring the transition from the nut to the headstock, I realized I wasn't straight on. And well, this happened.
    Would it be ok to cut the headstock a little thinner? From like 9/16ths to 1/2 an inch or around 7/16ths? My only issue is structural integrity and tuning stability. I don't want the headstock bending slightly up due to string tension. I'm using Gotoh vintage locking tuners so the height of the tuner won't be an issue for the headstock being slightly thinner. One small pass on my router sled and I can get the headstock level. Some insight would be very helpful
  17. Lunchie
    Lunchie Poster Extraordinaire
    Downstate Illinois
    What trussrod are you using? After talking to Warmoth I found out I ordered the wrong style. Luckily its only a $14 mistake :lol:
  18. sterkyyy
    northern colorado
  19. sterkyyy
    northern colorado
    Started on finishing up the neck. Because the headstock was too thin, I glued a 1/8 inch walnut veneer I cut up on the bottom. I'm hoping this will also negate the need for a string tree for the top strings. Fingers crossed. I got the 7.25 radius on the fretboard (I know crazy curve right?!? I like how it feels :D). Yes I radiused the fretboard with a sanding block alone. And yes, my arm is still sore. Who needs to workout when you can just build a guitar?[​IMG]
    taped up a razor blade to a quarter inch, the diameter of my inlays, then scraped over the inlays to get them flush with the fretboard.
    I got a better than expected shape on the neck. I shaped it slightly thinner than my other tele's neck, the one I based it on.
    Got around to placing the tuners on the headstock.
    Pressed the frets in. I taped off the fretboard so I could level all the frets, and they are pretty dang straight.
    Ta-da!
    frets and fret wire need to be cleaned up, but 90% of the neck is done. The other 10% being cleaning and finishing. I was so scared this neck would've been a train wreck, but I am quite pleased with the product. I'm gonna be out of town for the neck couple of days, but next week I will hopefully finish up the guitar. Don't quite know if I'll be able to finish with tru-oil for the thanksgiving deadline I placed. Not a big deal. I'd rather take time on it than rush it!
  20. crazygtr
    crazygtr TDPRI Member
    PR
    Is that a crack or just sanding marks? If it's a crack I see some trouble on your way. Hope it's just some need of sanding.
