First Build - Rob Robinette Micro Champ
Discussion in 'Shock Brother's DIY Amps' started by SJK45, Aug 14, 2020.
  1. andrewRneumann
    andrewRneumann Tele-Holic
    Cincinnati, OH, USA
    Just checking sanity here. You have a 240vac light and not a 6.3vac light, correct?
    If 240vac, then yes, you have to jumper from the switch. One end to each terminal where the brown PT wires will connect. That is a sweet transformer by the way!
  2. SJK45
    SJK45 TDPRI Member
    Yes - at the moment the light is 6.3v but I've ordered a 240 one. I suppose I could, alternatively, take the 6.3 out from the transformer and put that straight to the light? and from their to the heater wiring?
  3. SJK45
    SJK45 TDPRI Member
    Hi Rob,
    I am a bit confused - does that mean that the headphone resistor is on the speaker Jack?
    Spencer
  4. andrewRneumann
    Cincinnati, OH, USA
    Yeah, you understand what’s going on. Using the 6.3v winding is the traditional way it’s done. But... straight from the mains actually makes more sense to my way of thinking. It’s really up to you! Just make sure to use the right value for the bulb.
  5. D'tar
    D'tar Friend of Leo's
    WNY
    Yes, the resistor is wired between the shunt and ground on the speaker jack, the jack you have wired now is the tip-ring-sleeve jack and needs replaced with the Tip-shunt-ground jack.
    I like the recommendation to use a 1/8 trs headphone jack so there is no confusion of which jack is which.
  6. SJK45
    SJK45 TDPRI Member
    Actually I think that I see from the schematic (and your instructions) that the headphone resistor is on the speaker jack. Sorry should go back to that more often!
  7. SJK45
    SJK45 TDPRI Member
    Thanks for replying. I see that I've used a TRS jack rather than a TS jack but it doesn't matter this way around does it? Won't the TRS work fine as wired?
    S
  8. D'tar
    WNY
    On the trs jack... t=left headphone speaker, r=right headphone speaker, s=sleave/ground. The 10 ohm resistor needs to be between shunt and ground of the shorting mono jack to safely load the OT when the speaker jack is unplugged and using the headphone jack. Creatively you may get it to work but I would recommend sticking to the schematic and layout as designed to reduce future issues.
  9. SJK45
    SJK45 TDPRI Member
  10. SJK45
    SJK45 TDPRI Member
    Thanks - I’ll change those over. Not sure I have a TS socket so I’ll order one.
  11. SJK45
    SJK45 TDPRI Member
    9D9C89F2-AE43-4C5B-872B-6C36135ED4FD.jpeg 7AF8A0C8-72A4-4EF7-A348-3AA3D71C028A.jpeg These are my two valve wirings. I’m not at all confident that I’ve got this right. It was pretty fiddly.
    I’m not sure I’ve got the orange wire for the power tube right. It comes from the 470k grid stopper.
    Also I’ve wired it so the 6.3v green just stops at the power tube.
    The soldering is bad enough when I've not zoomed in! Interesting that I've spotted some soldering mistakes now that I've zoomed in though.
  12. SJK45
    SJK45 TDPRI Member
    4601C177-0E64-487B-8213-356AFDEE91EE.jpeg It’s not a great layout - next time I’ll drill my own holes!
    I mostly just need to connect the transformers now. Have to say I’m feeling a little lost though.
  13. D'tar
    WNY
    If you want "only" a "speaker out" or "only" a headphone jack to get up and going, we can help wire that trs jack. The way it is now the signal appears to go to the ring terminal which is no good for a speaker mono plug.
  14. D'tar
    WNY
    Please post the specs for your PT.
    I think we need to look at your power switch.... Your switch is not proper to switch both line and neutral.
  15. SJK45
    SJK45 TDPRI Member
  16. D'tar
    WNY
    With THAT switch remove the neutral and connect to the zero lead to the transformer and connect the 240 lead to the switch where you removed the neutral.
    andrewRneumann and Paul-T like this.
  17. SJK45
    SJK45 TDPRI Member
    I have the eight leads coming out of the transformer in two bunches of four. One bunch is coloured as in the right side of the diagram (Blue, grey, purple and brown). So I have a Brown 0v and a grey 0v.
    I don’t understand the connection You make between the 0 and the 120v? If I connect the blue 240v to where I put the neutral and then attach the neutral to the grey wire where do the other two (purple and brown) come in?
  18. andrewRneumann
    Cincinnati, OH, USA
    Dang just having the primaries on the right and the secondaries on the left in the wiring diagram was enough to throw me all off when I looked at it.
    D'tar likes this.
  19. D'tar
    WNY
    Ok, I edited my post to reflect what you are saying. If your voltages are 50% of expected then you will need to adjust
    Edit my edit. Lol
    Youneed to connect the grey and purple together for 240
  20. D'tar
    WNY
