First Build - Rob Robinette Micro Champ
Discussion in 'Shock Brother's DIY Amps' started by SJK45, Aug 14, 2020.
  1. SJK45
    SJK45 TDPRI Member
    This forum is amazing! Thanks everyone so much for all your help. Hopefully I'll get the remaining capacitors in the next day or two and I'll then post some pictures of the completed board.
    andrewRneumann likes this.
  2. James Knox
    James Knox Tele-Holic Silver Supporter
    Phoenix
    Paul-T likes this.
  3. SJK45
    SJK45 TDPRI Member
    I think that I’ve completed the circuit board now. The soldering is pretty dodgy but I’m getting better. The next one will be quite nice!
    I’m going to check the resistances and then starting populating the chassis.
    Lowerleftcoast likes this.
  4. SJK45
    SJK45 TDPRI Member
    Hmmm - maybe I should have put the wires on after I had soldered the chassis....
    I also feel that I may have put the board too close to the power input?
  5. andrewRneumann
    andrewRneumann Tele-Holic
    Cincinnati, OH, USA
    Looks like it’s coming along. What PT did you end up procuring? Does it have an HT center tap and/or 6.3vac center tap?
    How did the resistance measurements check out?
    Btw, what is this going in? Are you reclaiming something and need long pot shafts?
    So many questions.... ;)
  6. SJK45
    SJK45 TDPRI Member
    I ended up with the Ampmaker toroid one. We'll see how it goes.
    https://www.ampmaker.com/shop/240v-6-3v-toroid-power-transformer/
    I'm going to start wiring connecting the circuit board to the switches etc.
    The resistance readings were (target in brackets):
    Cathode V2 - 820ohms (820)
    Voltage dropping resistor 465ohms (470)
    Voltage dropping resistor 39.27 ohms (39)
    V2 Grid stopper 466.5k ohms (470k)
    V1B Cathode Resistor 1475k ohms (1.5k)
    V1 Load Resistor x 2 = 101.1k ohms and 98.5k ohms(100k)
    V1A Grid Stopper 32.5k ohms (33k)
    V1A Cathode resistor 1.476k ohms (1.5k)
    First time I've ever used a multimeter!
    Do I need to check the capacitors too?
    I'm not sure what it's going in yet - I'm going to build a custom cabinet. I'll probably cut the shafts on the pots as a final job.
  7. Tom Kamphuys
    Tom Kamphuys Tele-Holic
    The Netherlands
    I hope that is a typo.
    Edit: same for the V1a cathode
    SJK45 likes this.
  8. SJK45
    SJK45 TDPRI Member
    Yes the V1B was a typo - missed the decimal! Sorry. Correct readings are:
    V1B Cathode Resistor 1.475k ohms (1.5k)
  9. SJK45
    SJK45 TDPRI Member
    Some photos of the board in the chassis.
  10. Paul-T
    Paul-T Tele-Meister
    London
    Looking great!
    How did you mount the toroid? I've read about it but don't understand it.
  11. SJK45
    SJK45 TDPRI Member
    The Toroid sits between a round rubber ring on the bottom and a round metal plate on top. The toroid is then mounted by screwing a bolt through the centre directly into the chassis. It is held tight because the bolt screws down onto the round metal plate on the top - I'll send some photos when I'm back building. I'm hoping to do most of the remaining work this weekend.
  12. SJK45
    SJK45 TDPRI Member
    Just a quick question. I don’t understand what the 6.3v to all fill is meant to look like when actually wired up. Can anyone give me any tips?
    Am I simply connecting a twisted power wires to the valves @4 and 5?
  13. Tom Kamphuys
    The Netherlands
    SJK45 and andrewRneumann like this.
  14. Tom Kamphuys
    The Netherlands
    9 is also connected to the heater wiring. The two triode heaters in a preamp tube can be connected in series and in parallel. If I remember correctly, parallel results in the least amount of hum. So 4&5 are connected to one heater wire, 9 is connected to the other.
    f stands for filament.
  15. andrewRneumann
    Cincinnati, OH, USA
    You’ll be daisy chaining all the tubes that use 6.3V heaters/filaments in parallel. The wisdom here is to go in order starting with the least noise critical tube and end with the input tube. That way the least amount of heater current is flowing at the terminals of the most noise sensitive tube. In your case it’s pretty obvious that you should start with the rectifier (I’m assuming you are building the Micro Champ as Rob lays it out), then wire over to the power tube, and finally the input tube. You’ll need to create 3 sets of twisted pair jumpers between the pilot light and the 3 tubes. Good luck and I hope this helps!
  16. SJK45
    SJK45 TDPRI Member
    Thanks guys that’s very helpful. I’ve just started my wiring.
    I’ve done the power sockets - I’m just mulling over how to hook up the toroidal transformer. I think because of its design it doesn’t have lugs so my plan is to hook up the two brown 0-240v power wires to the switch and then run another set of wires from the switch to the light but I’m not sure? It seems a bit clumsy but in the absence of lugs I can’t think of what else to do. B07A5B08-9D02-466B-AAA5-B16386D53F1C.jpeg
  17. SJK45
    SJK45 TDPRI Member
    These are the wires out of the transformer...
  18. SJK45
    SJK45 TDPRI Member
    454E2D11-6202-42CA-BDFB-66161D20A8EF.jpeg Hm - sorry another question. I presume on this diagram the headphone jack is in fact the one on the right and the labels for it are
    g= sleeve,
    S=ring and
    t= tip?
  19. SJK45
    SJK45 TDPRI Member
    7FAC53A9-4693-4DB8-90C7-C225A034D1CF.jpeg This is how I’ve wired the headphone jack and the feedback switch. Not soldered it yet. Thanks
  20. robrob
    United States
    The headphone jack is on the left. TRS = Tip, Ring, Sleeve.
    The switched speaker jack is Tip, Switch (or shunt), Ground.
    D'tar likes this.
