First build plywood telecaster (proof of concept)
Discussion in 'Tele Home Depot' started by epimenio, Sep 27, 2020.
  1. epimenio
    epimenio TDPRI Member
    Rancho Cucamonga Ca.
    My wife bought me the Stewmac 54’ telecaster guitar template last month for my Bday.
    Decided to start this weekenD
    Body
    Glued up some plywood yesterday Cut the body shape out. Still need to route all of the cavity holes.
    Neck
    Used some scrap pine for the neck and maple for the fretboard. Need to read up more on slotting for the fretboard
    also working on jigs for neck profiling and finger board Radius
    Anywho I promised I would share
  2. AndrewG
    AndrewG Friend of Leo's
    Exeter, England
    Interesting project. Will you be installing a truss rod, adjustable or otherwise?
  3. 985plowboy
    985plowboy Friend of Leo's
    South Louisiana
    Looking to do something about like that myself
  4. blue metalflake
    blue metalflake Doctor of Teleocity
    ireland
    Be interested to see how it all comes together
  5. trev333
    Coolum Beach,Australia
    Today, I had one of those odd thoughts that come out of nowhere..:rolleyes:
    I wondered whether some of the places Bugs Bunny mentions in the cartoons were real places...
    like Cucamonga....:eek:.. that was the first one that came to mind...wooooo...:cool::lol:
    good luck with your build..;)
    crazydave911 and epimenio like this.
  6. jvin248
    jvin248 Poster Extraordinaire
    Lions & Tigers oh Mi !
    Good plan on making a prototype first ;) sometimes those turn into players. You learn it's not the fancy wood that's needed.
    I see you are preparing for the angled wiring slot. You don't need that if you get an electrician's drill bit and from the neck pocket drill flat from either the corner of the neck pocket to the corner of the neck pickup cavity to the control cavity, or from the neck pocket through the neck pickup cavity to the bridge pickup cavity then the usual bridge pickup cavity to control cavity hole.
    That way you can build the guitar without a pickguard and show off more wood.
  7. epimenio
    AndrewG, crazydave911 and Buell like this.
  8. epimenio
    That's a great idea thank you!
    crazydave911 likes this.
  9. Boreas
    Boreas Tele-Afflicted Silver Supporter
    Adirondack Coast, NY
    To make it a player, you may want to consider that piece of pine with the knot in it for the neck. What you could try is laying up some laminated wood or good plywood (Martin does it vertically on some less-expensive models) for the neck, then using the fretboard you planned. Pine isn't likely to be too stable for the neck - especially with that knot.
    epimenio likes this.
  10. epimenio
    I do plan to play it. Maybe convert it into a travel guitar to lug around with me when I am on vacation or traveling.
    I do have some extra plywood lying around and forming the initial neck profile is not hard, I was a little concerned about how plywood would hold up when I shaped it. I see your point. I might have some harder denser wood like oak in my scrap pile. either that or I can just buy a board and glue it up I guess. The pine was just a suitably sized piece of timber at hand.
    Thanks!
  11. halfdan
    halfdan TDPRI Member
    Weißenburg, Germany
    By all means do the plywood neck. The laminate construction is very stable and sometimes looks good as well. You can check my thread on the plywood tele. I have just finished shaping of the all-plywood neck and it was not harder, if not easier than a normal solid wood one.
