First Build - from scratch
Discussion in 'Tele Home Depot' started by thecableguy, Mar 1, 2013.
  1. thecableguy
    thecableguy Friend of Leo's
    Sherwood Park, Canada
    I measured from the heel 18.5" and marked where the nut edge will end up. I then laid the truss rod on the blank and marked where the channel will end.
    Continued the line all the way around:
    I then put my new StewMac truss rod bit in the router table and marked a line on the table corresponding to the edge of the bit. This in conjunction with the line on the blank tells me when to stop routing (thanks fletch).
  2. thecableguy
    Marked the channel depth which I will cut in a few passes:
    First pass:
    A few more passes and the rod fits just a hair below the surface.
  3. thecableguy
    Marked out the wider part to fit the barrel of the spoke nut.
    Another thing that Mr Fletcher does is recess the nut into the neck. I'm going to do the same.
    Adjusted the fence and routed.
    I used the same technique of drawing the line around the blank to tell me when to stop routing the recess.
  4. Rich Rice
    Rich Rice Poster Extraordinaire
    Chicago 'Burbs
    Nice when stuff works out, despite our best efforts.. ;) Looking good. Keep going!
  5. thecableguy
    After doing the same procedure for routing the pocket for the nut I chiseled the end of the channel square. It ended up being slightly past the line but it doesn't matter.
  6. thecableguy
    Thanks Rich! Fortunately I still have quite a bit of maple so if I completely screw up the neck I can start over. :D
  7. Rich Rice
    Chicago 'Burbs
    LOL! I hear ya.. I've probably wasted a whole tree by now.. one toothpick at a time..
  8. thecableguy
    And of course the best way to learn how to do something is to do it wrong.
  9. thecableguy
    Here's the second screwup:
    I wasn't paying attention on the side that was feeding in the same direction as the cutter. It grabbed a bit and pulled it a bit too far. Should be pretty easy to fix though.
  10. TotallyReptiles
    TotallyReptiles Tele-Meister
    Gainesville, GA
    Nothing wrong with the poor man's spindle sander. I got one :D
  11. thecableguy
    For sure. :D
    It's actually a template sander. Very useful.
  12. thecableguy
    Cut out the neck on the bandsaw.
  13. Glen Smith
    Glen Smith RIP
    Is that a 9" band saw? My 9" won't cut worth crap!
  14. thecableguy
    Yeah I'm pretty sure. It works great considering the price.
  15. thecableguy
    Put the neck back on the router sled and trimmed it to 20mm.
    Close enough:
  16. thecableguy
    Routed the neck and drilled tuner pilot holes:
    The neck has some really nice flame. I'm pretty impressed with the cheap wood from Windsor.
  17. thecableguy
    Marked out the fret positions:
    I think the blue fretboard will look pretty sweet, don't you? :twisted:
  18. thecableguy
    Did a test cut with my $12 Canadian Tire saw:
    Smacked in a fret with a plastic mallet:
    Looking good, most importantly it's square to the reference edge:
  19. Glen Smith
    Glen Smith RIP
    Would you have the item number on that Can Tire saw? Could you also measure the thickness of the blade at the teeth?
  20. thecableguy
    Hey Glen, the item number is 57-7407-8.
    http://m.canadiantire.ca/mt/www.can...ercraft+Reversible+Dovetail+Saw.jsp?locale=en
    I took my digital caliper to the store with me. Above the teeth it was 0.022" I believe. The teeth were angled out so I hammered them flat and now they read around 0.023" - 0.024", which is perfect. I can double check that when I get home. Before hammering they were 50 or 60 thou I think.
