First Build - from scratch
Discussion in 'Tele Home Depot' started by thecableguy, Mar 1, 2013.
  1. thecableguy
    thecableguy Friend of Leo's
    Sherwood Park, Canada
    Routed the edges and shaped the heel:
    That's all for tonight. Tomorrow I'll shape the headstock.
  2. crazydave911
    East Tennessee
    Looking good ;-)
  3. bcarter_1
    bcarter_1 Tele-Afflicted
    Salt Lake City, Utah
    +1
  4. thecableguy
    Thanks fellas. I have a small divot in the side of the template where the router tilted slightly. I'll probably just fill it with bondo and sand flat. Also I need to work the heel a bit more since it's not quite perfect. Might as well spend time getting the template as perfect as possible! :)
  5. thecableguy
    Shaped the headstock on the poor man's spindle sander:
    Routed the straight side of the headstock:
    Neck template done:
  6. Greg C
    Greg C TDPRI Member
    Florida, U.S.
    Great looking build so far!
  7. thecableguy
    Thanks Greg!
    StewMac order should arrive today according to FedEx. Speedy shipping from those guys considering I ordered at 1pm yesterday.
  8. thecableguy
    Whadda ya know! A box from StewMac! Less than 24 hours after ordering, talk about good service.
  9. thecableguy
    Time to start makin' a neck. I like this part of the board:
    guess I should put the pic in :)
  10. thecableguy
    Marked the neck centerline and marked a parallel line that will be the edge of the blank. That edge will get jointed and be the reference for routing the truss rod channel on the router table.
  11. thecableguy
    Neck blank is cut
  12. thecableguy
    This'll be the back of the neck.
  13. thecableguy
    This chunk o' maple is pretty dang flat. I'll just take a sliver off in the router sled to have a perfectly flat surface for the fingerboard to sit on. Then I'll thin it down so the neck + fingerboard = 1 inch. I'm off tomorrow so hopefully I can make some decent progress on the neck. G'night folks :D
  14. Bentley
    Bentley Friend of Leo's
    Kelowna B.C, Canada
    Wow, a) beautiful wood B)I like your method to routing.. There are other ways, but that's a cool way, that seems like it'd have little set-up.
  15. thecableguy
    Hey thanks Bentley. Yeah, that wood's not bad for being picked out of a pile at Windsor Plywood. :D Plus I can get 3 more blanks out of it.
    The techniques I'm going to use are from fletch's YouTube videos. His videos are awesome. He could easily make and sell guitar building dvds. But instead he kindly shares his knowledge so everyone can learn.
  16. Greg C
    Greg C TDPRI Member
    Florida, U.S.
    I watch David Fletcher as well. Is he on this forum too? I have found a lot of people who I have used for information here!
  17. thecableguy
    Hey Greg, yeah David goes by fletch on the forum. His work is super clean.
  18. thecableguy
    Took about 1.5 mm off the neck blank on the router sled.
    I might knock a mm or so off the fretboard and then a couple more off the other side of the neck to make it 1 inch plus a couple hundredths to allow for sanding.
  19. thecableguy
    Had a bit of an oopsie on the router sled but it's in the headstock area so it's gonna get thinned down past it anyway.
  20. thecableguy
    Set up the fence on the router table to act like a jointer. Lined up the outfeed with the bit and tested it on MDF. Made a nice straight edge.
    I ran the blank thru and it worked well. After I realized that I had the non surfaced side down, but the surfaced face and jointed edge ended up being perfectly 90° anyway. ;)
