First build. 5E7 PRO.
Discussion in 'Shock Brother's DIY Amps' started by ginomolinari, Oct 28, 2019.
  1. ginomolinari
    ginomolinari Tele-Meister
    Perugia, Italy
    Good morning to everybody. I just wanted to introduce myself and my first build. At this point I have a self built pine cabinet with a coffee bag grill with a 15" WGS G15C. The cabinet is open back and quite wide and I am hoping to emphatize the room effect when placed at least 3 feet away from any wall. (nerdy details)
    I have a Weber chassis, Classic Tone iron and I have self sourced all the parts, with the help of a old audio engineer friend. I quickly realised the value of buying a kit vs sourcing. I have now a small collection of wrong parts that is constantly growing. I have been using Mouser even though it gets a bit expensive with shipping and taxes to Italy.
    So far I am done with populating the board (besides the bias circuit) and it already looks pretty mixmatchy. The 220K 1watt resistors are an eyesore. But I am trying to get over it. I am using metal film Vishay for everything but the plate resistors which are carbon comp (they seem to be unusually close to specs, for now).
    I would love any feedback on the building process and parts sourced. Thank you!
  2. RollingBender
    RollingBender Tele-Afflicted
    SW Minnesota
    Love the cab!!!
    ginomolinari likes this.
  3. John E
    John E Friend of Leo's
    Connecticut
    I had a 5E7 that Mark Norwine built into a burnt out Fender Blues Deluxe. Had an EV12L. Weighed about 700 lbs... lol. Was loud enough to cause a stampede in Africa with the volume on 3.
    It was absolutely without question the very finest clean sound I have ever had in any rig. The way Mark structured the volume was it sounded incredible even with the volume on 1. Didn't need to be up loud to sound (SO) sweet.
    And yes, another one I stupidly sold due to G.A.S.
  4. D'tar
    D'tar Friend of Leo's
    WNY
    Looking great! IF you don't like the grid leak resistors change them out. Really no need for a 1w in that position. IMO.
    Love the grill cloth!
    Only thing I would change on the board is rotate the zip tie so the locking head is against the board for a cleaner look. :)
    Keep it coming!
    King Fan likes this.
  5. ginomolinari
    Perugia, Italy
    Thanks. I previously had 1/2 watt resistors for everything but the B+ droppers. However, after reading the specs of the Vishay metal film resistors I realised many have a voltage rating of 250. So i got scared and upped to 1 watt. I didn’t expect to be gigantic like that.
  6. King Fan
    Salt Lake City
    Nice build. Self sourcing is a pain, isn’t it? But extra points for effort.
    Speaking of wattage, whats the rating of the tiny and small MFs on the right end of the board?
  7. D'tar
    WNY
    I undestand:)
    Those resistors should never see anything close to that voltage.
    I enjoy sourcing my own components knowing I'll have enough spare parts for a whole other build!!!
  8. idjster
    idjster VERY grateful member Silver Supporter
    Saskatchewan, Canada
    Great build! Looks terrific!
  9. ginomolinari
    Perugia, Italy
    Thank you for the encouragement!
    The 820 ohms resistor is a Vishay 1/2 watt and rated 200 volts. I know it's crazy small but I feel it should be safe in that position.??
    The grill cloth is a coffee bean bag I got from a local roaster. He thought it was a fun idea so he let me pick my favourite bag from a big pile.
    Every day I learn something new and every shipment of parts is like WTF did I just order? Why doesn't anything look like everybody's else build? I guess that's part of the fun.
    D'tar and Tube Life like this.
  10. dan40
    dan40 Tele-Afflicted
    Richmond Va
    The cathode resistor and grid leaks only see a few volts as D'tar mentioned. No problem using the smaller resistors.
  11. ginomolinari
    Perugia, Italy
    OK, here is one of the many times when I get discouraged. I tried to implement a bias pot like I've seen many do and decided to go with a 22k trim pot and a 44k resistor. I even wanted the 1M safety resistor. So the upside is that the trim pot is very accurate to the decimal point. The bad thing is, well, obviously, it sucks! It is my first build and I wasn't expecting to win the price for neatest build but this is pretty bad.
    My question is, besides the looks, is it even safe?
    Any word of advice would be extremely welcome.
    Thanks.
  12. joeford
    joeford Friend of Leo's
    st. louis, illinois
    I've seen uglier on my amps and didn't die or get electrocuted. but maybe you could do a panel mounted pot so you could dial in the bias without having to open it up? hate to see a little dangler like that when everything else is so clean
  13. ginomolinari
    Perugia, Italy
    Radioshack PCB?
  14. ginomolinari
    Perugia, Italy
    Ok, I decided to create a separate circuit for the bias using half of a Radioshack PCB
    I am using a 47k resistor and a 22k trim pot (very accurate). I tested it and set it to the standard 56K. I'll touch it again when I'll have learned how to bias tubes, haha.
    Still not super pretty. PCB next to eyelet board (eeewww) but hopefully stable and safe. Now to leads wiring.
  15. Bill Moore
    Bill Moore Tele-Afflicted Silver Supporter
    Silver City, New Mexico
    I've found the pre punched boards easy to use for small add ons. Here's one in my 5E3, I just added a few turrets to make connections.
  16. ginomolinari
    Perugia, Italy
    Awesome. Is that a Fender RI pcb?
  17. Bill Moore
    No, It's a Tube Depot, works fine, and quiet!
  18. ginomolinari
    Perugia, Italy
    Man! A PCB sounds like a smart idea right now. I am in the middle of making all the leads and I am loosing my mind. It is so easy to oversee something and compromise the whole build. I proceed with extreme caution and taking my time.
    I have the pre assembled control plate next to the board to precut leads as much as possible to the right length. I have read that the lack of space in a tweed chassis makes it complicated to wire everything up and that proceeding bottom up is advisable. That’s where I’m heading but would love to hear anybody’s experience.
  19. King Fan
    Salt Lake City
    Hang in there, you're doing very well. I'm not sure exactly what people mean by bottom up, but double-check any backside wires about 18 times (18-check?), and test-fit the board as often as needed -- I curl each lead around a finger or fat pencil so I can keep them above the board while floating it into place.
    Your idea of keeping the control panel in exact left-right position is great. I also make each lead an inch or two longer than needed and cut it down to exact length before soldering but after routing, twisting, grouping it with other wires, etc. I tend to just copy the Fullerton wiring divas, hunting up as many pics like this as I can ...
    ginomolinari and Paul-T like this.
  20. ginomolinari
    Perugia, Italy
    Thanks man. I appreciate it. I was running the leads from underneath instead. What do you mean by wrapping the around a fat pencil? To keep them tight and not swinging around? That’s kinda of a cool trick. looking at all pictures out there is also a good tip. Not that I didn’t do it already but I guess it is never enough.
