Finished wood or Tolex?
Discussion in 'Shock Brother's DIY Amps' started by RatBug, Aug 28, 2019.
Finished wood cabinet or Tolex Covered?
  1. Finished Wood
    15 vote(s)
    37.5%
  2. Tolex
    17 vote(s)
    42.5%
  3. I like turtles.
    8 vote(s)
    20.0%
  1. RatBug
    RatBug Tele-Meister
    Arizona
    Thank you all for your opinions and info, with your help I have been able to narrow it down to either finished wood or a tolex covered cabinet. (Yes, that is supposed to be a joke).
    Wally, D'tar and awasson like this.
  2. Freeman Keller
    One more opinion. When I built my little kit amp it was intended to stay in my music room so I made a nice oak cabinet for it.
  3. Ricky D.
    Ricky D. Doctor of Teleocity
    Raleigh, North Carolina
    I was in the moving business for thirty years. Moving a wood cab Princeton with no damage is no big deal. Wrap it in a furniture pad, secure it with a big rubber band, and you have a package you can just pick up and carry. or get a padded cover (Tuki?), same deal but easier to live with-carry it by the handle.
    awasson, jsnwhite619 and D'tar like this.
  4. RatBug
    RatBug Tele-Meister
    Arizona
    Oh my, you just gave me an idea.
    I met an older guy (90+) that is selling off all his wood stock because he hurt his back and has decided it's time. :(
    I believe he has a bunch of quarter sawn white oak that would look awesome and take a beating.
  5. jsnwhite619
    jsnwhite619 Friend of Leo's
    Georgia
    I'll have to make a note of it. Bad timing on this thread -- I just put the Tweed on a Blues Jr cab since Wednesday!
    One thing I've found that makes a big difference in the "airy" top end and real, breathe-on-the-strings sensitivity is the baffle & cleat design. I know everyone talks about the difference in "floating baffles" of tweeds vs later fixed baffle designs. It is usually accompanied by describing the "attached at 4 corners" vs glued in designs. While that is an obvious difference, I think a bigger part of the equation is the fact that there is grill cloth on the front of the grill and tweed wrapped inside the cleat that is dampening the vibrations from the baffle. Compare that to a Brownface & onward design where wood screws from behind pull the bare wood baffle into direct contact with bare wood cleat. No dampening material in between. You wouldn't build an acoustic guitar with a strip of grill cloth under the bridge, would you?
    The poplar cabinet above is the second Pro Jr cab I've done with that rear baffle cleat style, the other was heart pine. Both turned out to be extremely touch sensitive and loud for their size. I think that the reason the bare wood cabs that still have the tweed look turn out brighter and louder is the same reason -- even though there is grill (100% fairly hard, synthetic material), there isn't nearly 1/16th of an inch of cloth between the baffle and the cabinet wood.
    As far as glued-in fixed designs, I am sure at this point that it was much easier & faster from a manufacturing standpoint. Having built and restored a couple Blackface cabs by now, drilling pilot holes in the cleats, mark & drill pilot holes in the baffle, and then running wood screws in with 9" of extension on a drill is NOT fun or quick. I hate it. A line of glue on the edges and shooting a few brads to hold it in place, then stick a velcro grill frame over that would be a more streamlined process, probably with less damaged cleats and baffles getting repaired in the process.
    Paul-T likes this.
  6. Freeman Keller
    A couple more pictures. I had never done box joints (I do lots of dovetails on my guitars but that is a whole different matter) so I whipped up a little jig for my router table
    Acceptable for a beginner. A few coats of tung oil (which I would use on furniture but never on a guitar)
    Some grill cloth and hung the little amp inside
    and bingo
    tubelectron, pelle31, awasson and 2 others like this.
  7. Chunkocaster
    In space with Ziggy
    I prefer the look of a nice wood finish.
    Build a road case to protect it.
    RatBug likes this.
  8. Freeman Keller
    In 1969 or 70 I built the solid walnut loudspeaker enclosures that I still use today. They are both furniture and functional, heavy as hell and sound great.
  9. SacDAve
    SacDAve Poster Extraordinaire Silver Supporter
    Rocklin Ca.
    Chunkocaster, Sean Mac, sds1 and 8 others like this.
  10. Lavochkin
    Lavochkin TDPRI Member
    Ithaca, NY
  11. tubelectron
    tubelectron Tele-Afflicted
    France
    Well, I think that both can give good aesthetical results... ;)
    I personnally choose Tolex because it's much more easy for me to achieve than a premium woodwork, for which I'm not tooled for building nor finishing... :oops:
    That's why I cast the Tolex vote... But it's me, OK ? :D
    That said, as a proof that both options can give you premium results : a few posts above, there's remarkable members woodwork and natural cab finish releases shown !
    -tbln
    Sean Mac, awasson, pelle31 and 3 others like this.
  12. RatBug
    RatBug Tele-Meister
    Arizona
    If those are your cabinets then you should know that it's those pictures that made me start rethinking my choice for finished wood.
    BobSmith likes this.
  13. tubelectron
    France
    Yes, they are ;)... But sorry for the embarrassment I gave to you... :oops::oops::oops:
    As I wrote it : both natural and Tolexed can give you good results... This one is a simple and very neat sample :
    I also ventured in Pinewood finishes a long time ago (1993). Well, OK... Not so bad, but... o_O :
    I finally re-Tolexed the cab some years ago (it's the same amp) - much better to my taste :cool: :
    And I also find it easier to do... But it's me, OK ? :D
    -tbln
    SacDAve and RatBug like this.
  14. BobSmith
    BobSmith Tele-Meister
    San Jose,CA
    If IKEA made head cabs, this is what I’d imagine they’d look like.
  15. awasson
    awasson Poster Extraordinaire Gold Supporter
    Vancouver
    Well, I was going for more of a Herman Miller meets Trainwreck aesthetic but sure. In this instance hardware, maple veneer and glue supplied by Lowe’s. Plywood by Rona but the amplifier is point to point hand wired by me. I haven’t used my other amps since I built it two years ago.
