Finish removal help
Discussion in 'Finely Finished' started by mefgames, Apr 12, 2021.
  1. mefgames
    mefgames Friend of Leo's Double Platinum Supporter
    North Bay, Ca
    Back 2010, I bought a Schecter Stilletto Bass with a broken headstock for parts. It's been hanging on the wall above my workbench since then. I decided to see if I could salvage the body, so I cut off the thru neck and am trying to remove the finish. I bought some stripper that says it removes poly, but this must be something else because it did nothing. Does anyone know what Schecter used for finishes back then and what to use to remove it? Sanding is tedious at best.
    Thx
  2. Lucius Paisley
    Lucius Paisley Tele-Afflicted
    Sydney, Australia
    As in the country?
  3. Lowerleftcoast
    california
    Heat?
    Matthias likes this.
  4. Freeman Keller
    I have tried to strip catalyzed poly for gluing down acoustic guitar bridges - none of the normal chemical strippers work. I have heard that some people use heat, never tried it. When I have to get to bare wood its plain old chisels and sandpaper. Use a RO sander and go thru the grits.
  5. Peegoo
    Peegoo Poster Extraordinaire
    Between the Raindrops
    If chemical stripper is not doing the job, it's probably catalyzed polyester. This is extremely tough stuff.
    If you can find it, get Aircraft Stripper. This is the strongest finish remover short of heat and/or fire. Scuff all glossy surfaces with sandpaper first to give the stripper a bit of a head start. It may take several applications and scrapings. It may not work at all, depending on the type of polyester formula that was used.
    If you decide to use a heat gun to remove catalyzed polyester, be forewarned: the heat does not soften it. Instead, it makes the finish pop off in shards like little splinters of glass (I am not exaggerating).
    What this means is you need to suit up and wear PPE (goggles, gloves, etc.). It also means you cannot do this job out in the yard because the little shards go flying and they will end up on the ground, and that will make your yard off limits for years to anyone that's barefoot.
    All the above sounds like science fiction but it's all true.
    bender66, tewiq, Grant Austin and 5 others like this.
  6. NoTeleBob
    NoTeleBob Tele-Holic
    Southwestern, USA
    The infamous "aircraft stripper" might work. Worth a shot for a quart to try. If it's some kind of epoxy mix, it might be nearly impervious to chemical stripping.
  7. dogmeat
    dogmeat Friend of Leo's
    Alaska
    put the stripper on heavy and cover it with clear plastic. you can work it around once the plastic is on. I use garbage bags, Saran Wrap, Vizqueen, etc. it traps the evil solvents and keeps them close to the work. you can fool around with it while its working and not have to touch the stripper. if everything works well, most of the finish sticks to the plastic
    that said, there is some finishes that "Aircraft Stripper" will not take off.
    old wrench likes this.
  8. mefgames
    North Bay, Ca
    Thanks for the replies. It must be catalyzed polyester to the nth degree. This stuff doesn't even want to come off with a heat gun. I've been using my RO Sander on the front and back, but the inside of the 2 horns is gonna be a bugger.
    Thanks again guys......
  9. mefgames
    North Bay, Ca
    Between the ROSS and RO sander, I've pretty much got the finish off. Oops, I sanded thru the paper thin quilt in front of the neck pickup. Still thinking about how to fix that. Maybe I can touch it up with something or maybe I remove the quilt on the entire front neck tru. One step at a time. The guitar was originally cherry red as shown in the photo, and I'm thinking re-doing the same color, but maybe bursting the edges darker.
    And yes I know the workbench is a disaster. I doesn't always look like that. Sometimes, it's worse......
  10. mefgames
    North Bay, Ca
    Had to remove the center portion of quilt veneer. The more I touched it up, the worse it looked.
    Kiwi_Neil likes this.
  11. mefgames
    North Bay, Ca
    Installed the 2 way truss rod in the neck and glued the FB yesterday. Cut and shaped the neck today.
  12. schmee
    schmee Doctor of Teleocity
    There's "poly"urethane which the stripper will work on,
    ..... and there's 2 part catalyzed "poly" which you need a heat gun for.
    The word gets used for different things.
    Well damn, just saw it's a zombie thread! Nice progress...
    Fretting out likes this.
  13. mefgames
    North Bay, Ca
    [QUOTE
    Well damn, just saw it's a zombie thread! Nice progress...[/QUOTE]
    I thought a Zombie thread was one that has been dead for a long time. So I looked it up. According to Urban Dictionary, A forum thread that has been dead for over a week and then out of nowhere some a**hole brings it back to life. You do learn something new everyday.
    On another note, here's todays progress.
    Drak and Kloun like this.
  14. Kloun
    Kloun Tele-Holic
    Orange County California
    That baby's looking nice.
  15. mefgames
    North Bay, Ca
    Body sanded and stained, neck got its first coat of Tru-oil.
    Kloun likes this.
  16. SacDAve
    SacDAve Poster Extraordinaire
    Rocklin Ca.
    Is that Waterfall Bubinga?
  17. mefgames
    North Bay, Ca
    I'm not sure. This was a Schecter Elite Bass neck thru with a broken headstock for parts, so I'm not sure of the quilt ??? veneer top. It is pretty though. After having it hang over my workbench for 10 years, I decided to rescue the body.
    I don't usually name my builds, but this has got Fontella all over it. She got a new coat today.....
  18. mefgames
    North Bay, Ca
    What could possibly go wrong ? Started wetsanding and and buffing and ran head on into to solvent pop. I wait 45 to 50 minutes between lacquer coats, and only spray on warmer days, so this was an unwanted surprise. Sure glad there's a Plan B. Removed all the finish and re-stained. Tomorrow, I will be applying Odie's oil for a more natural Warwick like finish. I will post pics when I get there.
  19. Sea Devil
    Sea Devil Friend of Leo's
    Brooklyn, NY
    Depending on what kind of stain you used, the solvent pop may have come from applying the lacquer too soon. Too bad; it looked nice like that. I'm sure oil will too.
  20. mefgames
    North Bay, Ca
    Denatured alcohol with ColorTone red, applied and dried for 2 days !!!
