finding the center line on your templates?
Discussion in 'Tele Home Depot' started by funkymann1, Mar 24, 2015.
  1. funkymann1
    funkymann1 Tele-Holic
    Cooper City Florida
    is there any easier way to find & draw the ctr line on your temples other then measuring the top & bottom & marking the middle?
  2. guitarbuilder
    A. If you had a compass that opens up greater than 6.5" you could swing an arc from each of the widest points intersecting each other. Where the arcs meet would be the middle of each section you do. Then connect those marks with a straight edge.
    B. Fold the printout in half making sure the extreme widest points touch.
    C. Download rhino. Open the drawing. Find the midpoints. Draw line through the mid points.
    D. In Rhino, after opening the drawing, use a " bounding box" under Analyze to create the rectangle around the body. Then draw a line between midpoints.
  3. metecem
    metecem Friend of Leo's
    berlin,now in Istanbul
    Assuming we're talking about physical templates, I take some known measurement like e.g. pickup route as reference and start from there..
