Finally! JMI style Vox AC15 build
Discussion in 'Shock Brother's DIY Amps' started by gusfinley, Nov 21, 2019.
  1. gusfinley
    gusfinley Tele-Holic
    SLC, UT
    I've been planning this build for around two years.
    My "Dream Vox amp"
    - AC15 Power stage with Top Boost and Normal Channels
    - Cut Control
    - Master Volume
    - Pentode/Triode Strip
    - JMI Era Construction!
    - Premium parts ( Mercury/Heyboer Transformers, Phillips Mustard/Wima Caps, Mullard Amparex Tubes)
    - Weber Alnico Blue Dog
    - Official Vox-Licensed JMI Era AC15 cabinet
    I previously considered a build like this impossible, but everything fell into place at the right time.
    I plan to start next week during Thanksgiving Vacation - if I can wait that long.
    A one-way discussion about it here:
  2. Snfoilhat
    Snfoilhat Tele-Afflicted
    Oakland, CA
    This is shaping up to be something special.
    Would you share your source for that style of tag board, please? I've only gotten my hands on a couple after parting out an organ and a ton of desoldering. I would be glad to be able to buy them new.
  3. gusfinley
    SLC, UT
    I don't have the part number on hand at the moment, but Allied Electronics and RadioSpares are in cahoots now, so we can get Radio Spares (RSpro) components without international shipping rates!
    Snfoilhat likes this.
  4. NSB_Chris
    NSB_Chris Tele-Meister
    New Smyrna Beach Florida
    Very interesting chassis configuration! I am not familiar with that amp. Can you show how that chassis fits into the cabinet.
  5. gusfinley
    SLC, UT
    Well, I got a jumpstart on this project!
    I made the final arrangements on the chassis, verifying the components fit from the 3D model with the actual hardware.
    I had to drill holes for the Fuse Block, cinch-style tag strips, Euro-style barrier strip/terminal block, axial capacitor mounts, etc.
    Here is the final assembled product ( minus electrical components )
    I've got a video uploading to youtube that I'll add to this post later.
  6. milocj
    Michigan
    If you look at his first picture you can see that there's a flange at the bottom with three holes in it. The chassis screws down through these onto a "slider board" which is just a piece of wood that is a bit wider than the chassis and the same depth as the cabinet.
    The cabinet will have a groove in it created by two cleats on each side. The slider board slides into the groove just like a shelf would into an entertainment center or an armoire and the height is just right so that the top of the control panel will touch the inside top of the cabinet. Once the back panel is screwed on the whole thing is held in place.
    A little difficult to describe but very some when you see it done.
    NSB_Chris likes this.
  7. gusfinley
    SLC, UT
    Here is the video with a tour of the chassis:
  8. gusfinley
    SLC, UT
    Got the heaters wired up!
    The tubes are glowing!
  9. Mongo Park
    Mongo Park Tele-Holic
    Winnipeg
    74C7689A-C989-4DDE-9A97-8C619DCBBD9F.png You can buy those tag strips on eBay.
  10. gusfinley
    SLC, UT
  11. gusfinley
    SLC, UT
    muscmp likes this.
  12. gusfinley
    SLC, UT
    Tagboards are being loaded. I worked up this jig so I wouldn't have to fight the pots and wires that are in the chassis.
    Unfortunately, I found I used my 1/2 watt 1Meg resistors on the input jacks instead of the 1/4 watt 1 meg resistors. I'll need to order a few more before I can complete the tagboards.
