Finally... a cure for my 6G2 trem thump
Discussion in 'Shock Brother's DIY Amps' started by King Fan, Nov 10, 2019.
  1. King Fan
    King Fan Friend of Leo's
    Salt Lake City
    The 6G2, with its famous tremolo, also seems to be infamous for tremolo thump. Search for the term on the internet, and it seems *many* of the cases occur in this otherwise superb amp (although the problem also occurs in other bias-wiggle trem circuits). Believe me, I searched the internet... over a couple of years.
    Lots of solutions are suggested in lots of threads. A popular fix that helps some folks is to solder three (in some threads just two) 47pf 'snubber caps' at specific points in the trem circuit. Sadly, this didn't help mine much. It may be a cure for a different type of trem noise.
    Pulsing trem noise has lots of possible causes. To be clear, mine wasn't optical roach 'ticking' (no roaches here) and it wasn't the common (maybe even intrinsic) "whoof-whoof-whoof" of hiss amplified by bias-wiggle. It was like a drummer with a tom playing along with the trem: "thump thump thump."
    I've read threads on several sites where some poor guy tries a *ton* of solutions with very little luck. Lower bias, swapping 6V6s L for R, better matching, worse matching, shielded cable to the trem grid, lead dress (tho this sometimes works), and on and on. For sure I tried lower bias, a popular suggestion, but it did zero to mine.
    Finally I saw a different fix from a guy who, IME, is seldom wrong, Steve Luckey. In this el34world thread (see Reply #1), he suggests a diode across the intensity pot (something he borrows from a PR trem fix). I tried it today, and the thump is *gone.*
    John How, RatBug, Wally and 8 others like this.
  2. schmee
    schmee Poster Extraordinaire
    Cool... thanks!
    King Fan likes this.
  3. kingofdogs1950
    kingofdogs1950 Tele-Holic
    Franklin, Texas
    I used this fix about fifteen years ago, and it works perfectly.
    I have a Mojotone 5f11 vibrolux (built by MT), close relative to your 6g2. My tremolo works perfectly with no issues.
    Mark
  4. theprofessor
    theprofessor Friend of Leo's
    Chattanooga, TN
    Fantastic! That's all it took? One diode? Great solution!
  5. King Fan
    Salt Lake City
    Good point -- the 5F11 is a kissing cousin, and it does seem prone to the familial thump.
  6. King Fan
    Salt Lake City
    Yeah, amazing, huh?
    IIRC, Prof, in that thread the snubber caps had worked for you, and you passed the idea on to others who liked 'em too. I wonder if we had different diseases needing different cures. :)
  7. tubelectron
    tubelectron Tele-Holic
    France
    It also works well on Princeton and Princeton Reverbs.
    -tbln
  8. King Fan
    Salt Lake City
    Yes, and in fact it sounds like there you can do a couple other things as well. Steve Luckey's scheme:
  9. Mongo Park
    Mongo Park Tele-Holic
    Winnipeg
    beauty thanks for sharing. I sort of gave up and moved on but this will be a nice fix.
    Cheers Ron
  10. 82LesPaul
    82LesPaul TDPRI Member
    Nashua, NH
    Glad it worked out. Wonder if the diode should be a going in position on the 6G2 layout? Steve Luckey is a wealth of knowledge. Helped me solve a nagging issue on my Gibson Falcon.
  11. King Fan
    Salt Lake City
    Thanks, Ron, your thread helped me in my research. Hope this can help you back...
    Yeah, well, it's staying in my 6G2 layout! :) AFAIK not everyone gets the thump, so I'm not sure it should be universal.
  12. Mr Ridesglide
    Mr Ridesglide Tele-Afflicted Ad Free Member
    Bloomington, MN
    Very good information there!
  13. Mongo Park
    Winnipeg
    I tried a few things and in the end installed a switch to turn it off when not in use to remove the unwanted effect, but this did not really seem total right and the effect was present when using this feature, which in the end was a part of the amp. It sounded gre4at but the negative effect bothers me. So I am hot to apply the above, goog on Ya for perservering.
    Cheers Ron
