Do any of ya'll lay down coats of clear before grain filling when finishing a body with binding... to prevent sanding the binding when leveling?
I'm also wondering if it's a good idea to be able to see the binding through the color for ease of scraping? I'm afraid that after I spray white primer and silver color that it may be obscured.
Here's the long version of my question with some background:
I'm finishing my first bound body (Pine, Inca Silver, and Parchment double binding) and finding myself concerned about sanding the binding thinner on the sides while leveling the surface using the process I normally use for unbound bodies.
(I'm spraying a 1.5# cut home-brew spirit varnish made with a blend of natural alcohol soluable resins (Shellac, Sandarac, Copal, Mastic, Benzoin) and mixing in pigment powders.)
I like to get the surface super flat before shooting color so I spend a good bit of time on prep work to get the surface almost finished before starting... If that makes sense. Usually following sealer and filler with several clear and primer coats before color.
My thinking is that it would make a lot of sense to grain fill and level before binding. Since I ordered the body from Guitar Mill, this is not an option for me right now.
I'm thinking the next best route would be to start with spraying clear and build up enough coats to protect the binding while sanding. Then do grain filler and level.
Thoughts?
Thoughts?
